Go to Post The ideals that are held by myself and by many of the longtime FRC mentors and volunteers whom I consider friends and colleagues are bigger than FIRST, and we will find (or make) another vehicle for them if we are forced to. - Jared Russell [more]
Unread 20-01-2009, 15:22
FRC1672's Avatar
FRC1672 FRC1672 is offline
Team 1672
FRC #1672 (Mahwah Robo T-Birds)
FRC1672 is on a distinguished road
Problem with Motor direction
Our programing / electronics team was trying our bench top test and we found that one of our motors was traveling backwards. The jaguar is receiving a backwards signal as denoted by the LED's color being 'orange-ish'.
We set up the bench top test stock from the KOP. Our cables were hooked up correctly. The motors did drive. We are using the WPI library (unmodified).
Any insight if its just the WPI library? Is there a physical fix (reversing cables???) other than reversing the motors in the library coding.
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Inverting the direction of a Motor willson.thomas Programming 19 17-03-2008 20:16
problem with motor speed bsbllpss Electrical 3 29-01-2008 10:07
CIM Motor Bias Direction jonboy Motors 1 28-01-2008 07:58
Motor Spin Direction archiver 2000 6 23-06-2002 23:43
