Go to Post What really drove us was not our achievements, but our failures. - BEEKMAN [more]
Unread 20-01-2009, 16:19
thedog1's Avatar
thedog1 thedog1 is offline
Vice-Lead of Electronics
AKA: Nate Bechtel
FRC #1647 (Iron Devils)
Team Role: Electrical
thedog1 is an unknown quantity at this point
Power cunsumption
All right. Does anyone have a gragh or something that contains all of the stats for the components, such as the voltage, current, and wattage. Thanks
Unread 20-01-2009, 16:22
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Power cunsumption
which components are you specifically interested in?
Unread 20-01-2009, 16:35
thedog1's Avatar
AKA: Nate Bechtel
We need the CRIO and the digital side car.
Unread 20-01-2009, 16:51
The cRIO is capable of drawing 20W, but usually draws about 10W.
The DSC is capable of drawing 45W, but usually draws less than a tenth of that. The unloaded use is close to zilch, as it is just a few LEDs and some simple logic. The real load is what you attach to it - Servos, mostly. To eyeball it, total up your outputs and assume 90% efficiency in the switchers. Then add a little margin on that for the LEDs.
Both of these use switching supplies, so Watts is the correct unit to work in.
If you are interested, the datasheet and schematic for the digital sidecar are posted. It will be probably be easier to just measure the draw.
Unread 20-01-2009, 17:02
thedog1's Avatar
AKA: Nate Bechtel
Thanks so much for all of that.
O/I POWER? popo308 Electrical 21 06-08-2007 13:16
ROBO-POWER 12th-martyr General Forum 2 07-04-2004 18:02
OI power rocko Electrical 3 06-02-2004 19:30
No Power UCGL_Guy General Forum 8 05-02-2002 15:54
