Go to Post I think that if you're using semantics to pass inspection you're trying hard to be lazy (Trust me I'm really good at doing it). - Thayer McCollum [more]
Unread 20-01-2009, 17:15
Robertoell's Avatar
Robertoell Robertoell is offline
AKA: Roberto Tirado
no team (Yellow Fever)
Robertoell is an unknown quantity at this point
Send a message via MSN to Robertoell
Flexible Material
Was wondering if anyone knew of a material that could bend completely and is tough so it could pick up ones of those "moon rocks or empty cells or super cells"
We were thinking of using foam but the problem of using foam is that we need another motor and we want to keep it with just one motor.
Thank you ! 1872 I think its the number of my team not really sure...
Yellow Fever PR
-Love working with Photoshop
Unread 20-01-2009, 17:18
typharn91's Avatar
typharn91 typharn91 is offline
the nerdy-hippie
AKA: Mr.Gamer
FRC #0180 (S.P.A.M.)
typharn91 will become famous soon enough
Send a message via AIM to typharn91
Re: Flexible Material
Lexan is a somewhat easilaly bender material just add heat and you can bend it
team shirts i have acquired 21,33,47,79,86,111,179,180,217,228,233*2,237,1114,1124,1390,1523,1557,1889,1902*2,1983 and more...ohh yeah and i can crash linux on a daily basis
Unread 20-01-2009, 17:21
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
By 'bend completely', what sort of bend radius are you looking for?
and
By 'pick up', how do you intend on picking things up? roller? tongs? spikes? magic?
Once we know these, we can help you.
___________________
- Tennyson, Ulysses
Unread 20-01-2009, 17:24
Robertoell's Avatar
AKA: Roberto Tirado
My team was thinking of making a conveyor belt with a flexible material attached to it, so for when it reaches top. The top will bend the "material" and lets go of the ball. Falling into a chute and then restoring its original shape or similar. Shape of a hook but not so curved.
Yellow Fever PR
Unread 20-01-2009, 17:27
Bend some aluminum, if you're thinking of something like the yellow tower on this robot.
Unread 20-01-2009, 17:46
aznkazoon's Avatar
aznkazoon aznkazoon is offline
FRC #2410 (Metal Mustangs)
Team Role: Marketing
aznkazoon is an unknown quantity at this point
Well if it need to be plastic, then just go to the store, and buy some of the tubberware* That stuff can be adjusted with heat, and is really sturdy.
*I am not sure if that is the exact name, just pretty much look for the huge bowls that people store food in that are plastic. Or debate tubs will work too.
Bam!
Unread 20-01-2009, 17:54
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Could have forks protruding from the belt on springs of some sort so when it hits a solid something it bends back and releases again as it goes back down.
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
Unread 20-01-2009, 17:59
Robertoell's Avatar
AKA: Roberto Tirado
lol plastic forks why didn't i think bout that XD ! thanks! gonna try it but ... probably is gonna break.. :S
Yellow Fever PR
Unread 20-01-2009, 18:55
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
No, I meant metal forks.
Unread 20-01-2009, 21:45
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
You should use some thin polycarbonate. You could make forks with this.
Unread 07-02-2009, 12:58
aznkazoon's Avatar
I found something better, our team is using somekind of polycarbonate sheet. They needed it to bend, so we took a propane torch and heated it up for a while, and it worked well.
Bam!
Flexible Floating Idler Tensioner AndyB Technical Discussion 23 22-07-2008 11:05
flexible materials Adama Inventor 4 26-12-2006 16:28
Flexible, Bendable Rod blue_crew Technical Discussion 7 30-03-2006 19:18
Super flexible Wire want2modmygt Electrical 10 18-01-2006 18:39
Flexible cable management Doug G Electrical 12 10-11-2005 14:04
