Go to Post ...your stress reliever is a ziptie with the end cut off so you can pull it straight through. It really works! - Storcky [more]
Unread 20-01-2009, 17:53
samboydh's Avatar
samboydh samboydh is offline
FRC #0702
samboydh will become famous soon enough
Robot Pre-View
http://www.youtube.com/watch?v=39dXQ...e=channel_page
oh yea look at them wheels.
Unread 20-01-2009, 18:03
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Robot Pre-View
I hope those wheels are a joke. If not then adding wheels does not increase traction. Traction is only influenced by the normal force and the coefficient of friction. Also it looks like the front wheels are unpowered which would decrease your total force you can apply as well. Basically. The amount of wheels doesn't matter this year, and all of the wheels should be powered for the maximum usage of available traction.
Mentor 2415
Unread 20-01-2009, 18:18
guakam0li1089 guakam0li1089 is offline
FRC #1089 (Mercury)
Team Role: Communications
guakam0li1089 will become famous soon enough
Re: Robot Pre-View
but doesnt having less wheels work better? i think so because with less wheels you are distributing more wieght per wheel making the friction due to gravity greator. (not sure if its right though, just something me and a few other students were disscussing)
Wise men talk because they have something to say; fools, because they have to say something.
Unread 20-01-2009, 18:22
AKA: Sean
Re: Robot Pre-View
This is partially right. If all of the wheels are driven then it doesn't matter. Each wheel will have less traction per wheel due to a lower normal force per wheel but the total traction will be the same as the more wheels will add up to the same value. Either way having 16 wheels does not improve traction at all and having unpowered wheels even with 16 wheels means this drivetrain will have less traction than a simple 4wd design.
Mentor 2415
Unread 20-01-2009, 19:01
samboydh's Avatar
FRC #0702
Re: Robot Pre-View
all the wheels are powered. That clip dosnt do justice to how well it preforms.
Unread 20-01-2009, 19:05
AKA: Sean
Re: Robot Pre-View
At least all the wheels are powered. You are wasting a large bit of the weight budget with those wheels though.
Mentor 2415
Unread 20-01-2009, 19:51
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: Robot Pre-View
Are you using any sort of traction control or steering augmentation? If so, I'm going to have to rethink my plans...
Get yer robot source code here!
Unread 20-01-2009, 20:22
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: Robot Pre-View
I'm sorry to burst your bubble... but more surface area will have next to no effect on the Glasliner surface. Do the math/physics you may want to think about saving all that weight for something else.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 21-01-2009, 05:48
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Robot Pre-View
Not at all arguing the physics of friction, but one thing that may change with the extra wheels is how the robot performs while turning. While with this robot, you will certainly not get any more friction when driving in a straight line, distributing the frictional force of the wheels around the robot means that when turning, the amount of torque that each wheel is supplying will be different as its distance to the axis of rotation, for both the linear and transverse friction of the wheels.
While I have not done any actual math, playing with vector diagrams a little yields this:
So it seems that not only are more wheels hurting your weight, they're actually decreasing your ability to turn.
Interesting; have your tried to do comparative testing with only four wheels? Or someone correct me if I'm wrong.
--Ryan
FRC 766, 2015-, Mentor
Unread 21-01-2009, 06:37
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Robot Pre-View
Some of you missed the point of the video. Watch again and listen carefully to the video. First run is without traction control, second run is with traction control. Notice the obvious difference in traction and acceleration.
This obviously is a proto-type. Any team smart enough to pull off what they did know about wheel configuration.
Good job team 702.
Doug Leppard
Unread 22-01-2009, 14:43
seandherbert seandherbert is offline
FRC #0207
seandherbert is an unknown quantity at this point
Re: Robot Pre-View
http://www.youtube.com/watch?v=fClOU0yYuCA
Unread 25-01-2009, 09:38
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Robot Pre-View
Another thing to condsider with multiple wheels. Unless each wheel is EXACTLY the same diameter, only the larger wheels will make contact with the floor. On carpeting this wouldn't make much of a difference, but since we are playing what is essentially a flat floor it should make a difference IMHO.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 25-01-2009, 12:46
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Robot Pre-View
We originally had ideas to utilize multiple wheels to increase traction but after review our physics a little realized that that would just further distribute weight and traction would remain the same.
Unread 25-01-2009, 13:20
dtengineering's Avatar
AKA: Jason Brett
Re: Robot Pre-View
As much as I agree with the statement that "in the simplified theory of friction as taught in high school physics class, extra wheels should not increase traction", it is important to remember that the simple relationship between normal force and resultant force makes some assumptions that may or may not hold true in a practical environment.
For instance Formula One race cars evidently find that having a larger contact patch improves traction. This does not contradict the theory taught in high school physics, but does mean that some of the assumptions made in that theory are not valid in the race track environment.
For instance the "high school" theory assumes that neither surface deforms due to the normal force (remember that the regolith lies over top of carpet, and is a fairly thin material...), nor fails under the resultant force. Given the "white powder" produced by spinning wheels as reported on CD, there is definite surface failure during dynamic friction of highly loaded wheels. Perhaps this is less of an issue with lightly loaded wheels....
Perhaps they are on to something with this design, perhaps not. I suspect not, but if the team has tested multiple wheels and found them to be an improvement then they have my congratulations for not being bound by the assumptions of a simplfied theory.
Unread 25-01-2009, 15:11
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Robot Pre-View
That's So Awesome.
How many wheels did you have in the back? 8? 10?
In theory more wheels will not increase traction but it will change how your robot handles with the traction thats given. So maybe having that super awesome wheel thing in the back is actually helping them turn with the trailer......
-Dustin Benedict
pic: ThunderChickens 2008 Robot View 3 Paul Copioli Robot Showcase 7 21-02-2008 20:58
pic: ThunderChickens 2008 Robot View 1 Paul Copioli Robot Showcase 9 20-02-2008 23:27
pic: ThunderChickens 2008 Robot View 2 Paul Copioli Robot Showcase 2 20-02-2008 16:46
pic: 217 Robot ISO view CD47-Bot Robot Showcase 8 01-03-2004 13:09
pic: ROBOT FRONT VIEW CD47-Bot Robot Showcase 4 25-02-2003 13:34
