Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 20-01-2009, 18:06
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
<R18>
part B states:
The Trailer Hitch must be rigidly attached to a fixed location on the ROBOT, with the long dimension of the Trailer Hitch horizontal and the opening of the C-channel facing away from the ROBOT. The horizontal center line of the Trailer Hitch must be 2-13/16 inches above the floor.
But if you build a robot with a 6 wheel design, with a drop down middle wheel, the robot would pivot and therefore the height of the hitch would change. Anyone have ideas/opinions? The rest of my team thinks that the change in height will be small enough to be irrelevent, but I want to be sure.
I'd post this on the Q&A myself, but no one knows the password to get on.
Unread 20-01-2009, 18:12
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: <R18>
http://forums.usfirst.org/showthread.php?t=11160
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: <R18>
You do not need your team's official login to read the Q&A, it is only necessary to submit questions.
The GDC has already answered this question:
During inspection, acceptable tolerance on the Trailer Hitch altitude will be +/- 0.25 inches. During the MATCH, acceptable tolerance on the Trailer Hitch altitude will be +/- 0.50 inches, based on the dynamic motion of the ROBOT.
Unread 20-01-2009, 18:13
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Re: <R18>
You can find your password in TIMS. Ask one of your mentors (your TIMS contacts) to go in and find it.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 20-01-2009, 20:22
ZakuAce's Avatar
AKA: Garrett
Re: <R18>
Ok, thanks. I did go to the Q&A section to look, don't know how I missed that. Thanks
Lap Indicator Rule <R18> Clarification t-raum General Forum 1 28-01-2008 11:04
