Go to Post Figure out where you have to start and what end result you want, from there, all you have to fill in is the middle. - Beth Sweet [more]
Unread 20-01-2009, 18:26
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Lightbulb DS tty serial and crio run speed
Is there a tty or serial library to use the DS pins as a serail output yet?
If not i wish to make one, can we use interrupts and the timers on the processor in lab view?
anyone?
I have a serial interfaced lcd screen i would like to use...
also, not related but, the lab view code runs extremely slow when being run from the laptop and using the front panels to monitor the robot, does it run faster when there is no monitoring? Because .3 seconds an iteration is disappointing.
I see in logic, Black and White
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Speed in Autonomous run abeD General Forum 8 14-02-2003 00:18
Take the boxes and run! Rich Wong General Forum 16 21-12-2002 00:07
