Go to Post I'm absolutely certain there are simpler ways of accomplish the same things. I'm simply not the best that FIRST has to offer in this regard and part of what drives me to keep going is the desire to get better at achieving an elegant solution with as few superfluous processes as possible. - Madison [more]
Unread 20-01-2009, 21:47
Re: DS tty serial and crio run speed
The front panels and probes definitely slow down execution, the amount of slowdown depends on the amount of data and the rate of data change.
As for the serial port, look in the documentation. I'm pretty sure that the standard serial VIs will work.
Greg McKaskle
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Speed in Autonomous run abeD General Forum 8 14-02-2003 00:18
Take the boxes and run! Rich Wong General Forum 16 21-12-2002 00:07
