Unable to set team number
We've had a couple problems with our driver station. We can't really do much of anything with it because we can't do the following:
Driver station team number change doesn't work. Driver station software upgrade drops-out after holding "select". The procedure we are stuck on is in section 3.1.5: Setting Team ID and Updating the DS software of the Control Systems Manual. Has anyone else come across these problems with the station? Any idea as to a solution? |
Re: Unable to set team number
We were not able to set the team number until after the software upgrade. Others have stated the same.
Search on the Usfirst labview robotics forums - there are several problems there similar to yours where people have been walked through different solutions. |
you should remove it then be sure that u put it on usb1 in the driverstation...Read The Manual |
I do want to add one thing. Make sure the file is correctly named.
I see someone watches Arby n' the Chief.
| Can not set team number on DS | TekClaz | FRC Control System | 2 | 23-12-2008 14:25 |
| Unable to re-image cRIO | slavik262 | FRC Control System | 4 | 09-12-2008 21:05 |
| Unable to resolve ADC_CH0 | p_a_3 | Programming | 4 | 03-02-2008 01:42 |
| Lego Team challenge set - software | paula | Lego Mindstorm Discussion | 0 | 09-03-2005 09:37 |
| What was the best team set up? | xavior06 | General Forum | 6 | 15-04-2003 23:16 |
