Go to Post "Individual": I am the FMS. I don't want to talk to you. Robot: FMS, is this true? I still have stuff for you. Actual FMS: No, what gave you that idea? Are you feeling ok? Repeat. Field Monitor: FTA! We need a counselor! - EricVanWyk [more]
Unread 20-01-2009, 17:15
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: How do i find a variable and use it on Labview
Originally Posted by BLAQmx View Post
Every variable can be either read or written to.I n that sense there is only one variable but two states. This single variable may have multiple copies of readers and writers, but they are all reading and writing from the same place in memory.
Let me know if the screen shot I have attached helps at all.
I think you made a typo in your comments. The one says it has one writer and multiple readers, but it actually has one reader, and multiple writers.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 20-01-2009, 21:22
You click on the ???s and choose from the list of controls. If you rename a control, the variable also gets renamed.
Greg McKaskle
Unread 20-01-2009, 23:37
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
I'll double check and repost the screenshot. Thanks!
In your example you have variables with "X" and "Y" in them all i get are "?"s how did you rename the variable.
BLAQmx where do you find the boolean, string, and numeric all i can find are local, global, and shared and how do you name them.
Tutorial: Local Variable, Global Variable, and Race Conditions
See the section Implementing a Global Variable
There is also a video of there tutorial here.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 21-01-2009, 00:51
I'm not really sure why you want to use variables. You might be thinking too much in terms of procedural programming (like C or even BASIC) instead of treating LabVIEW as a dataflow programming method -- which it is.
In LabVIEW programs, wires are essentially the variables. They're what "hold" values as they move from where they're produced to where they're used.
Unread 21-01-2009, 01:17
dgraves702 dgraves702 is offline
FRC #0702 (Bagel Bytes)
dgraves702 is an unknown quantity at this point
Exactly. All you need to do is wire the output from your Get Axis VI from the Joystick Palette to the Set Speed VI (or equivalent if you are using your Drive motors) from the Motors Palette. You don't need to use variables at all.
Unread 21-01-2009, 07:30
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Excellent point, Alan! Maybe Chris was getting too hung up on that concept.
In general, you should be able to do all of your programming without using global or local variables. Wires can go "everywhere" by simply wiring "through" structure boundaries or exploiting shift registers or sequence locals (look 'em up). Variables are only really necessary when
A) You want to clean up your block diagram since having wires everywhere can get out of hand.
or
B) You've got a set of parallel processes that need to share data (although I believe there may be a few other more advanced options that could be used). Processes WILL NOT run in parallel when they are wired together (since a wire cannot be read from until it is written to whereas variables can be read from at any time).
Another suggestion - check out Highlight Execution mode. It can be really handy for helping understand program flow and debugging.
Russ
Unread 21-01-2009, 10:50
Chris11246 Chris11246 is offline
FRC #1647
Chris11246 is an unknown quantity at this point
I was just trying to make a test vi that doesnt use the Crio but i couldnt make a value that could be used as the motor value that could be changed but still give me a value(i wanted to make it accelerate or decelerate and show the value of the motor) I can get what i want using the Crio stuff but I was just trying to figure out how to test it.
Unread 21-01-2009, 10:58
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Simply create a control on the front panel to input your value.....then place an indicator to the output of your coding to show the result. Make sure to create a While loop to let it run.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 21-01-2009, 17:50
blackdeath's Avatar
blackdeath blackdeath is offline
AKA: Shawn
FRC #2506 (Saber Robotics)
blackdeath is an unknown quantity at this point
Just take the axis from the unbundle by name and hook it to the tank drive/arcade drive.vi input
Variable rollover with Labview (suggestions?) kamocat NI LabVIEW 7 22-08-2008 08:30
NEED GENERAL HELP on how to find programming and animation resources delphi demon General Forum 1 02-04-2007 15:58
how do i find the camera with labview? CompMaster NI LabVIEW 0 16-02-2006 12:52
How do you find time for sports and robots? Whalley General Forum 50 23-03-2005 12:11
