Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 20-01-2009, 23:55
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
1726 Beginning Week Three
We're doing pretty well so far, we almost have the beta version of our robot built. All that needs to be made now to have a complete prototype bot is the part to move the balls from the floor to the top, which is mostly designed and should be done in the next few days, as well as some wire management and mounting of the electronics. Our robot as currently planned has a turreted shooter, which is loaded by a helix hopper and a roller on the floor. This all mounts on a wide format four wheel drive chassis.
http://www.youtube.com/watch?v=qNH4hb7crFU
Any comments or questions are greatly appreciated!
Unread 20-01-2009, 23:57
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: 1726 Beginning Week Three
We're having some trouble getting a good way to rotate. Can you explain how yours does?
Unread 20-01-2009, 23:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We are posting photos of our build too.
http://photos.project1726.org/thumbnails.php?album=34
(this might answer your question about how it rotates)
Unread 21-01-2009, 00:00
CCCP's Avatar
CCCP CCCP is offline
stanislav Sekacov
AKA: The Russian
CCCP will become famous soon enoughCCCP will become famous soon enough
here is a up close image http://photos.project1726.org/displa...up&cat=0&pos=3
and here is the video of the pully system http://www.youtube.com/watch?v=50Q3ToSvbIg
Unread 21-01-2009, 00:01
shawn1231 shawn1231 is offline
FRC #1997
shawn1231 will become famous soon enough
What are you going to have feeding the balls into that shooter during competition? Are you using an auger? If so what is going keep the balls from shooting when you don't want them to?
Unread 21-01-2009, 00:03
MrForbes's Avatar
AKA: Jim
We are planning on using a helical path for the balls to follow upwards, with a center rotating part to drive them around and up the path. At the top will be another small roller that will pop them into the shooter. We need to get this all built and see how it works. We might need to make a gate to control the balls at the top.
CCCP's Avatar
stanislav Sekacov
AKA: The Russian
this is how we are feeding thje balls to the turret http://www.youtube.com/watch?v=LlUgVpRckS8
Unread 21-01-2009, 00:10
Andy L's Avatar
FRC #1458
Wow, quick good responses, thanks.
Unread 21-01-2009, 00:11
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Awesome work guys. I have always admired your team.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 21-01-2009, 00:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Great work! It is awesome to see a proof of concept that a design like this can be done with simple components and fairly simple tools (from the looks of things).
We will be attempting a similar setup that we will begin working on shortly.
Judging from the pictures it looks like the was (or at least could be) done with basic wood working tools such as a jigsaw, table saw and a drill. Is that accurate?
Unread 21-01-2009, 00:19
MrForbes's Avatar
AKA: Jim
Well...it maybe could...but we did use the lathe for some parts, like making the bearing holes in the roller end caps, and making shaft size adapters for the sprockets onto the transmission and motor shafts, and the output shaft for the Fisher Price little gearbox we made.
I think everything except that output shaft could be made without the lathe, if you were good at drilling holes into round things, and getting them properly centered.
Unread 21-01-2009, 00:22
FRC #1997
I looked at the pictures which I greatly appreciate. And also thanks for the quick reply, but I'm still a little fuzzy. I can tell how it all goes together but what did you use to make it rotate. I mean what is that part exactly? Or is it custom? I really appreciate the video and pictures, our team is trying the same thing and I marvel at how quickly yours went together, we're still stuck in auger land, but we're quickly moving to the shooter. Just curious, why did you choose the one sided shooter like that? We had been looking at two smaller rollers on either the sides or the top and bottom but this looks simpler. What made you go with form of shooter?
Unread 21-01-2009, 00:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Sorry, I should have specified what I was talking about. Of course it is much easier to use a lathe or mill for some of the shaft and bearing parts as close tolerances must be kept on those parts for the system to run well.
Provided we can CAD exactly what we need (and my CAD skills, while not great, should be sufficient) we do have access to a machinist that will assist us with small parts like the things you mentioned.
Once again, the pictures are awesome! It looks like you guys are making great progress. Now I just have to convince my team to be as transparent as you guys are (I guess we have to be taking pictures before we can be sharing them though...).
Unread 21-01-2009, 00:27
MrForbes's Avatar
AKA: Jim
It's a Southwest part...called a Swamp Cooler Blower Pulley. It's a 12" diameter, 1/2" V belt pulley, which happens to have nice flat spokes that are perfect for cutting off and bolting to a piece of plywood. The magic trick is using 3/8" belt on it, so there's an indent for the support bearings to ride in. (also we are going to put normal kit wheel bearings on it to replace the previous year KOP slide bearings)
We tried it and it worked.
Unread 21-01-2009, 00:32
MrForbes's Avatar
AKA: Jim
It's interesting how this works out. It could be that some teams will copy some of our ideas, which I think is great. It could be that some of these teams will do a better job with their copy, than we did with the original! which is also great, although it takes some hard thinking to figure out how to explain this to all the team members....but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me".
Besides, when we goof up, we get quick feedback! ask 842 about that
MOEmentum FYI - Week 3: It's Week Three Already?!? Mr MOE General Forum 0 18-01-2009 19:23
week 1: Three Things I've Learned Jeremiah Johnson General Forum 55 04-03-2008 00:36
pic: 1726 week 4 TheOtherGuy Extra Discussion 29 04-02-2008 00:36
Only 1 week until the beginning of the 2007 DARPA Urban Challenge in VictorVille, CA Bongle General Forum 14 31-10-2007 11:08
beginning of a match Jess1513 Rules/Strategy 2 10-02-2005 22:05
