Re: 1726 Beginning Week Three
Besides, when we goof up, we get quick feedback! ask 842 about that ![]() |
We are doing a very similar design to yours except I think our shooter will be placed different from yours. I was just wondering if you were planning on controlling the speed of the shooter to adjust to various distances.
Looks GREAT!! -Mike |
Kevin (programmer) says "yes! We're planning on using the camera or an ultrasonic sensor to determine distance and adjust the shooter speed accordingly. Human control of the speed shows distance is controllable"
(he was in the kitchen eating cereal....so I asked him....) |
Have you tested the effectiveness of altering the distance by changing wheel speed? If so, was spin up/spin down time a factor? |
We didn't have much time to mess with it tonight (got it firing just before it was time to close the shop
) but we can test this tomorrow and see how effective motor speed is on distance. The roller is spinning at 3700 rpm from one CIM on a 5" roller and 1.5" compression, so spin up time might be a little higher than we expected, but once again, we'll test that tomorrow ![]() |
Oh okay that's what we are looking forward to also we got the camera tracking the colors and following them but we have not had a chance to test the ability of judging distance. We are going to using 5" rollers as well but we are running a CIM at a 2:1 so we are more in the range of 2600 rpm. Hopefully we can get the shooter up the rest of the way tomorrow to be able to test distance by Wednesday......
-Mike |
#7
Our previous test of the shooter was at about 2200 rpm (9 tooth motor sprocket, 22 tooth roller sprocket). Tonight's test was at about 3700 (15 tooth motor sprocket).
#8
I was doing a quick gear box just using a 12 tooth spur gear on the motor to a 24 tooth spur gear on the output. Now that I seen that I might have the kids test a shooter with the higher range......... did you guys happen to measure how much extra distance was coming out of that extra 1500 rpm?
-Mike |
#9
i saw the banebots gearbox on what appears to be the banebots 545 motor...is this correct? If so, why did you choose this motor for this application, and if you guys can, or have, what did you get as the output RPM of that planetary? Thanks a lot...looks great!
#10
We were looking at using the same exact planetary with that motor, however using it in a different application than a turret....thats why I was asking for the output RPM....thanks for the info though! |
| MOEmentum FYI - Week 3: It's Week Three Already?!? | Mr MOE | General Forum | 0 | 18-01-2009 19:23 |
| week 1: Three Things I've Learned | Jeremiah Johnson | General Forum | 55 | 04-03-2008 00:36 |
| pic: 1726 week 4 | TheOtherGuy | Extra Discussion | 29 | 04-02-2008 00:36 |
| Only 1 week until the beginning of the 2007 DARPA Urban Challenge in VictorVille, CA | Bongle | General Forum | 14 | 31-10-2007 11:08 |
| beginning of a match | Jess1513 | Rules/Strategy | 2 | 10-02-2005 22:05 |
