Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 20-01-2009, 20:36
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
How to wire included sensors
This is the first year that we'll actually be using the sensors given to us by FIRST and I'm wondering how one would go about wiring them. The accelerometer looks like I could just solder on the male end of a few PWM cables and be set, but I'm not too sure what to do with the gyro. I remember from previous years the gear tooth sensors required power from the main board to run and I'm not sure if that's the case with these new sensors. We'll also be using the two included optical encoders. I'm pretty sure I understand those, the A and B channel are signal lines with common ground and power. And all these are connected as analog inputs, right? Three channels for the accelerometer, one channel for the gyro, and two for each optical encoder.
EDIT:
I took another look at the sensor manual but that didn't help very much.
2ND EDIT:
Also I would definitely take any suggestions for building a shaft to mate with the spindles of the optical encoders from the Kit of Parts. I see that they have small grooves so that would could probably machine an axle with ridges on it to fit the grooves.
Compiling...
Compiling...
Unread 20-01-2009, 22:45
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: How to wire included sensors
You can use PWM cables and just solider them on. The encoder uses digital inputs not the analog. The Gyro and accelerometer use the analog inputs. Open the examples in Labview for each of these sensors and study them to test your sensors and knowledge.
The encoders attach directly to the machined end of the drive shaft on the Toughbox. You can buy mounts for them for $4 each at andymark.biz.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 20-01-2009, 22:55
I'm still not clear on which pads go to which pins. I'm not sure if the +0V refers to signal or ground, I'm assuming the latter. Also the gyro has two sets of pads, does that mean it connects to two analog inputs?
We plan to mount two of the encoders on free wheels without gearboxes or motors, so I don't think a ToughBox couple is what we're looking for...
Compiling...
Compiling...
Unread 20-01-2009, 23:08
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
The gyro board has both a temperature sensor and a gyro. Gyros are sensitive to changes in temperature, so the temperature sensor can be used to reduce some of that error. Both should be connected to analog inputs.
The +0v is the ground line.
Unread 21-01-2009, 01:07
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
My team are soldering a 3x1 female header to the boards rather than soldering the PWM directly. The advantage of this is that a PWM connector can now plug in directly to the board, so if we need to rewire it, it is a simple unplug.
The digikey part number for this is S7001-ND.
Unread 27-01-2009, 08:41
Bandgeek80001 Bandgeek80001 is offline
FRC #2867
Bandgeek80001 is an unknown quantity at this point
Hey,
We're a rookie team and somewhat behind...
We're having trouble figuring out which of the 11 holes we should solder a PWM cable to. We can see the voltage and ground markings, but does this mean that we have to run power for each axis we want data from? Also, what are the two holes outside of the box for?
If anyone could post some pictures or a really good description, we would be very grateful.
Unread 27-01-2009, 09:30
Originally Posted by Bandgeek80001 View Post
Hey,
You only need one ground and one power connection. There are 3 extra of each to give you the options to choose what wiring method is best for you. Unfortunately, that means that rookies may be overwhelmed with options.
If you only need one axis, use a 3 conductor cable (PWM cable) to connect to the appropriate column of pins.
If you need two axis, you may
  • use 2 3 conductor cables (do the first option twice)
  • use 1 3 conductor cable (the first option) plus a lonely wire that is connected only to the second axis
If you need all three axis, you may
  • use 3 3 conductor cables (do the first option each time)
  • use 1 3 conductor cable (the first option) plus two lonely wires that are connected only to the other axis
  • use a 5 conductor cable to pick up the top row
  • use a 3 conductor cable to pick up the three axis and a 2 conductor cable to do power and ground
This list isn't exhaustive, if you can find something that works for you, go for it. Just remember not to reverse power and ground!
Unread 27-01-2009, 21:54
FRC #2867
Thanks, we're on the right track now.
Unread 29-01-2009, 22:11
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Question Re: How to wire included sensors
Okay, on my team, we understand the wiring on the gyro and the accelerometer, but we don't get which one is the analog module......... We SHOULD know this, but we cant figure out where to look........
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 30-01-2009, 13:37
It's the cRIO module closest to where the cRIO ethernet ports are.
How To Wire The Encoder JamesByrne Electrical 6 19-01-2009 13:15
How to wire solenoid valves???????? JCODER Pneumatics 3 31-01-2008 20:11
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
How to wire a 40 Amp Breaker? dez250 Electrical 6 09-09-2003 11:17
