Go to Post As it stands your design defies physics (and breaks 1 of Karthik's 2 Golden Rules). - JesseK [more]
Unread 21-01-2009, 00:53
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Re: 1726 Beginning Week Three
We are doing a very similar design to yours except I think our shooter will be placed different from yours. I was just wondering if you were planning on controlling the speed of the shooter to adjust to various distances.
Looks GREAT!!
-Mike
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 21-01-2009, 01:00
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Kevin (programmer) says "yes! We're planning on using the camera or an ultrasonic sensor to determine distance and adjust the shooter speed accordingly. Human control of the speed shows distance is controllable"
(he was in the kitchen eating cereal....so I asked him....)
Unread 21-01-2009, 01:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by squirrel View Post
Kevin (programmer) says "yes! We're planning on using the camera or an ultrasonic sensor to determine distance and adjust the shooter speed accordingly. Human control of the speed shows it's controllable"
This is the major thing we are worried about and unfortunately don't have a great way to test before committing to a design.
Have you tested the effectiveness of altering the distance by changing wheel speed? If so, was spin up/spin down time a factor?
Unread 21-01-2009, 01:28
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We didn't have much time to mess with it tonight (got it firing just before it was time to close the shop ) but we can test this tomorrow and see how effective motor speed is on distance. The roller is spinning at 3700 rpm from one CIM on a 5" roller and 1.5" compression, so spin up time might be a little higher than we expected, but once again, we'll test that tomorrow
Unread 21-01-2009, 01:40
redbarron's Avatar
Mike Barron
AKA: Mike
Oh okay that's what we are looking forward to also we got the camera tracking the colors and following them but we have not had a chance to test the ability of judging distance. We are going to using 5" rollers as well but we are running a CIM at a 2:1 so we are more in the range of 2600 rpm. Hopefully we can get the shooter up the rest of the way tomorrow to be able to test distance by Wednesday......
-Mike
The Red Dragons
Unread 21-01-2009, 01:53
MrForbes's Avatar
AKA: Jim
Our previous test of the shooter was at about 2200 rpm (9 tooth motor sprocket, 22 tooth roller sprocket). Tonight's test was at about 3700 (15 tooth motor sprocket).
Unread 21-01-2009, 01:59
redbarron's Avatar
Mike Barron
AKA: Mike
I was doing a quick gear box just using a 12 tooth spur gear on the motor to a 24 tooth spur gear on the output. Now that I seen that I might have the kids test a shooter with the higher range......... did you guys happen to measure how much extra distance was coming out of that extra 1500 rpm?
-Mike
The Red Dragons
Unread 21-01-2009, 09:27
Brandon Holley's Avatar
i saw the banebots gearbox on what appears to be the banebots 545 motor...is this correct? If so, why did you choose this motor for this application, and if you guys can, or have, what did you get as the output RPM of that planetary? Thanks a lot...looks great!
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 21-01-2009, 11:47
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
It's a Southwest part...called a Swamp Cooler Blower Pulley. It's a 12" diameter, 1/2" V belt pulley, which happens to have nice flat spokes that are perfect for cutting off and bolting to a piece of plywood. The magic trick is using 3/8" belt on it, so there's an indent for the support bearings to ride in. (also we are going to put normal kit wheel bearings on it to replace the previous year KOP slide bearings)
We tried it and it worked.
This is great COTS engineering for a turret! What kind of support bearings are you using?
How much weight do you think your turret can handle ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 21-01-2009, 12:01
MrForbes's Avatar
AKA: Jim
This is the new 2009 KOP Banebots RS-545 motor, installed on the old 2007 KOP Banebots 64:1 36mm planetary transmission. That transmission is still for sale from Banebots, and although it is sold with an RS-540 motor, it's easy to swap the motors if you have a new pinion gear (we bought several pinion gears and an extra transmission in 2007 because we thought we might use the transmission then, but did not).
Unread 21-01-2009, 12:03
MrForbes's Avatar
AKA: Jim
Right now it has some of those funky grooved bearings from a previous KOP, which are desinged to be used on metal slides. We ordered some of the new KOP wheel bearings, which should fit in place of the funky ones. See our 2009 Build photo gallery on the NERDS web page for more detailed photos.
I don't know how much weight it can handle...but it's handling about 12 lbs right now, and seems to be pretty sturdy. I dontk now how it would fare against a direct hit from something during a match...we'll have to think about that. If the robot fell over, it could be damaged.
Unread 21-01-2009, 15:19
We were looking at using the same exact planetary with that motor, however using it in a different application than a turret....thats why I was asking for the output RPM....thanks for the info though!
MOEmentum FYI - Week 3: It's Week Three Already?!? Mr MOE General Forum 0 18-01-2009 19:23
week 1: Three Things I've Learned Jeremiah Johnson General Forum 55 04-03-2008 00:36
pic: 1726 week 4 TheOtherGuy Extra Discussion 29 04-02-2008 00:36
Only 1 week until the beginning of the 2007 DARPA Urban Challenge in VictorVille, CA Bongle General Forum 14 31-10-2007 11:08
beginning of a match Jess1513 Rules/Strategy 2 10-02-2005 22:05
