Go to Post As long as they're not destroying each other, LET THE TEAMS PLAY! - Travis Hoffman [more]
  #31   Spotlight this post!
Unread 18-01-2009, 16:39
amariealbrecht's Avatar
amariealbrecht amariealbrecht is offline
Alicia Albrecht
FRC #2177 (The Robettes)
Team Role: Electrical
amariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura about
Send a message via AIM to amariealbrecht
Re: pic: Wheel problem.
we havent had this problem yet but i have heard of some other teams with the same problem...they said it was from the carpet to the playing surface but i am not entirly sure!
Good luck,
Alicia Albrecht
Electrical Subteam
The Robettes 2177
  #32   Spotlight this post!
Unread 18-01-2009, 22:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Originally Posted by Mechkrunch View Post
And to answer Squirrel's question we where using 3/4" #10 screws.
The wheel hubs are sized for #8 screws. Did you drill them out before you tapped them for the #10's? If not, you could have stressed the plastic when you used the tapping tool to create your threads.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #33   Spotlight this post!
Unread 19-01-2009, 13:07
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
This is the link to the AndyMark Cad file, which clearly shows the sprocket mounting holes to be 3/16" (.1895).
http://lib.store.yahoo.net/lib/yhst-...lick-Wheel.pdf
The tap size for a 10-32 is about 5/32" (75% thread clearance), clearly smaller than the existing hole in the wheel. It would seen to be far better to open the hole slightly for the #10 bolts to go through, and jamb nut the bolt/sprocket /wheel assembly together. #8 bolts would be too sloppy in the existing holes (maj. diam. of .164").
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
  #34   Spotlight this post!
Unread 21-01-2009, 07:03
Hodge1
Smile Re: pic: Wheel problem.
Checked the wheel mounting hole size last night on a wheel, and they are definitely NOT sized with a 10-32 or 10-24 tap hole. An 8-32 clearance hole is about right, but a little more sloppy than I would normally like. If you keep your sprocket and spacers centered on the wheel hub, the 8-32 bolts should work fine, and you will eliminate sprocket runout. Sorry for my previous post, but I even checked with A/M and was assured the CAD drawing was correct a 3/16".
Sweat the details
  #35   Spotlight this post!
Unread 07-02-2009, 09:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by Teched3 View Post
.... I even checked with A/M and was assured the CAD drawing was correct a 3/16".
Did you ask someone at AndyMark to try to push a 10-32 screw through the hole in a wheel?
Autonomous Two wheel problem??? fallen751 Programming 4 11-02-2007 23:07
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
