Go to Post The sign applause was definately one of the best moments I had ever witnessed at a FIRST event. Who knew silence could be so loud? - Koko Ed [more]
Unread 21-01-2009, 08:26
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: Wireless and wired simultaneously?
I was using this setup also on XP and I found that I *had* to set the default gateway explicitly. When I used the wired connection to 10.*.*.6 XP was creating a default gateway on that domain and I lost connection to the internet on my wireless. I added explicit default gateways for both the 10.* (the laptop itself) and 192.168.* (the wireless router) and life was good again.
If you have problems you can use either 'netstat -r' or 'route print' to see what your default gateway was before and explicitly add it to your wireless TCP/IP settings.
HTH
Jim
stumble Uppon and Wired Stuart General Forum 2 05-04-2008 20:41
2006 WIRED Vex Challenge and Milwaukee Vex League Kevin Kolodziej Off-Season Events 15 04-12-2006 09:59
Wireless programming and debugging link heydowns Programming 2 23-01-2006 21:39
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
Dean and Segways in Wired Magazine!!! David Kelly Dean Kamen's Inventions 18 17-10-2002 12:16
