Go to Post "which came first, the hamster or the toad?" - dlavery [more]
  #46   Spotlight this post!
Unread 20-01-2009, 12:50
Brandon Holley's Avatar
Re: Round Belting - Solid vs. Hollow, Polycord vs. McMaster
Originally Posted by Rosiebotboss View Post
For clarification purposes, the 'round belting" we are talking about as actually called what?
In the McMaster online catalog I found this, EPDM Rubber Cord and Polyurethane Cord. Is this the 'right stuff'?
Mcmaster P/N# : 59725K704.... this is the same kind of 'stuff' your looking for.
This particular variety is 1/4" dia., orange in color (which is slightly softer durometer and matches rosie's colors ), and a 2" min. pulley diameter.
You can pick whatever variety you actually need.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #47   Spotlight this post!
Unread 20-01-2009, 12:58
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Yeah, that's the stuff. I must have had a brain cramp. I couldn't find it. Thanks, Brando.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
  #48   Spotlight this post!
Unread 20-01-2009, 14:24
no problem!
  #49   Spotlight this post!
Unread 20-01-2009, 18:36
rjamesjr's Avatar
rjamesjr rjamesjr is offline
FRC #2165
rjamesjr is an unknown quantity at this point
Our team is trying out round belting, but we are having some trouble carrying the ball. The belts keep splitting and not grabbing the ball. Any suggestions?
  #50   Spotlight this post!
Unread 21-01-2009, 09:53
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Use more belts, closer together, with pulleys? Use less distance between axles ? Use less compression of the ball? Place the axles so that they form triangles between three, instead of having each one directly across from each other?
I'm not sure what you meant by splitting.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
  #51   Spotlight this post!
Unread 21-01-2009, 10:09
You need to make sure you put grooves in whatever pulleys you are using....otherwise, there is nothing keeping the belts from separating (i'm assuming thats what you meant by splitting).
  #52   Spotlight this post!
Unread 21-01-2009, 10:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Unless he means that the cords themselves are splitting when formed into a loop??
If that's the case, then your tension is way too high on your belting.
If you just heat up the ends & melt them together & let the completed loop cure for a while, they should suffice for a while.
Also, if you can, try using very thin wall shrink tubing to assist in holding the joint together as an added protection from the splitting.
Don't forget to put that on before you join the two ends though... or you may have a bit of an issue.
Another trick I heard of was to "tin" the ends?? I heard that terminology thrown around the shop before, but I'm not sure what it means exactly.
Maybe throwing some solder on the ends of the plastic helps the adhesion process a bit??
I'll have to find out, & report back here with my findings. Maybe it was just team slang for the heating process we used in the past? Not sure.
  #53   Spotlight this post!
Unread 21-01-2009, 11:41
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
if you want the Green belting, the 6mm stuff is the same but in Green. Part #8112K33
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #54   Spotlight this post!
Unread 21-01-2009, 17:06
rjamesjr's Avatar
FRC #2165
The belts are separating while carrying the ball, and the ball is getting stuck.
  #55   Spotlight this post!
Unread 21-01-2009, 17:21
Jared Russell's Avatar
Taking a year (mostly) off
Maybe increase the tension in the belts?
  #56   Spotlight this post!
Unread 21-01-2009, 17:24
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Try increasing the tension in the belts.
"we don't build robots, we build people"
  #57   Spotlight this post!
Unread 21-01-2009, 17:37
are there grooves in the pulleys?? if no, then add them....if yes, increase tension
  #58   Spotlight this post!
Unread 21-01-2009, 19:28
Jno
Depending on the length of your belting (especially using thin poly cord), you will need extra rollers in the middle. Or you can just use some thin 1/4" AL rod to support the belts from flexing inward too much. Belting takes a lot of tweaking and babying to work perfectly.
  #59   Spotlight this post!
Unread 31-01-2009, 12:15
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Has anyone tested the green rough type belting vs. the orange or clear not-as-rough types? Any opinions on either of them?
Also, from everyone's testing, what seems to be a good minimum spacing between your belts for this year's game?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Hollow Shaft optical encoders magical hands Control System 2 24-03-2005 09:12
Hollow Shaft optical encoders magical hands Robotics Education and Curriculum 0 03-02-2005 22:56
Polycord Belting Claires4sorrow Technical Discussion 1 31-01-2004 13:37
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
HELP! ChiefDelphi needs Green 1/4" polycord! Brandon Martus General Forum 1 14-03-2002 19:25
