Re: Brake/Coast Jumper
Posted by Joe Ross at 2/20/2001 3:59 PM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon. In Reply to: Re: Brake/Coast Jumper Posted by Josh Vetter on 2/19/2001 11:55 PM EST: : We haven't tried the brake at all, but there is a motor that we certainly could benefit from the use of it. I have a question about it though. If what it does is basically short the terminals, will it drain the battery? It only shorts the output to the motors and doesn't affect the input from the battery. You can easily see this effect on the fisher price motors, if you have a free one. First try turning the output shaft when the motor is disconnected. It should be possible to backdrive the motor. If you then get someone to connect the two wires coming from the motor, you will find that is MUCH harder to turn the output shaft. |
| Drill Motors: Pins IN or Pins OUT | Caleb Fulton | Motors | 28 | 03-02-2003 14:19 |
| Programming Port | GreenDice | Programming | 12 | 10-01-2002 09:14 |
| broken jumper on controller | Mike Soukup | Technical Discussion | 5 | 22-10-2001 20:49 |
