Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 21-01-2009, 11:53
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: Team Update 5
Originally Posted by MikeDubreuil View Post
With that said, I do believe the GDC reserves the right to change the game at any time. We could have a new game piece in the next team update
Ah!. I missed that. (It's not in the spec - it's in the contract - I knew we needed a lawyer on the team). Now we have a good engineering lesson. Look for the fine print. When the customer has some fine print that says something like "the government reserves the right at any time to change the specifications ....." beware. You may have to anticipate such changes and their possible consequences (and build that possibility into your price ).
Fortunately, we had a Plan B contingency for the case where the idea didn't work. The idea worked but the specs have changed so Plan B will now come in handy.
Unread 21-01-2009, 12:01
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Team Update 5
Remember to put a diaper on your helper monkey.
Hi!
Unread 21-01-2009, 13:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update 5
Imagine what happens to the trailer, practically speaking, when it starts whipping around the back of the robot. The trailer will want to tip left/right (aka roll) when it changes lateral directions. This puts extreme forces on the contact point of the trailer tongue and the robot hitch. Enlarging the hole at the contact point allows for the trailer to roll and tip slightly without damaging the trailer tongue or the hitch. I for one am very glad of this change as it reduces the torsional reinforcement our hitch mount needs since our drive train is designed to strafe and drift. Part of engineering is to at least have considered the realm of implications and possibilities of a particular design before going forward. It's impossible to figure them all out, which is why engineers usually create room for error in their designs.
Why do people consistently post that they think the GDC is out to get them when they clarify the rules?
GitHub
Unread 22-01-2009, 22:19
Engineering Mentor
AKA: Wally Ritchie
Re: Team Update 5
1. The original hitch design (Prior to REV A) allowed the trailer to roll freely. REV A (before the kickoff) added a close fit pin which eliminated this roll.
2. If the GDC wanted to allow limited roll, it could have modified the hole added by REV A. This would not have affected pitch.
3. REV B now allows about plus or minus 10 degrees of roll and pitch. Under some pitch loads, it also allows the 1018 steel cylinder to be levered against the aluminum C channel.
4. I'm glad that you think this change benefits your design. When the design of a component changes there are usually some that benefit, some that are harmed, some for which the change is irrelevant, and some who remain in ignorant bliss.
I don't know. But what does that have to do with this discussion? We certainly don't think the GDC is out to get us. And this certainly isn't a clarification! But the fact is that the design of a major component has been changed in a significant way and we still think that such spec changes should at least be accompanied by an explanation.
It may be that this is new territory for the GDC with a major component of the robot supplied as part of the field. This introduces a new element to the engineering - mating with an externally specified and supplied component. I think that this is a good thing that opens up new opportunities. But I think that specs for a component of the robot system and a the specs for game piece are of a different character. If the intent is for the piece to be an integral part of the robot on the floor, then the specs should be frozen at kickoff and not changed without both good reason and cogent explanation.
Just my $0.02
Unread 22-01-2009, 22:25
Engineering Mentor
AKA: Wally Ritchie
Re: Team Update 5
Picture of side by side Hitch, Swivel Rev A and Rev B
Unread 22-01-2009, 22:34
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Team Update 5
http://www.chiefdelphi.com/forums/at...5&d=1232678195
The link is not working for me.
Unread 22-01-2009, 22:39
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Team Update 5
Where do you find the updated GE drawings?
All I can find on the FIRST site is 9036A and 9040.
Unread 22-01-2009, 23:10
Engineering Mentor
AKA: Wally Ritchie
Re: Team Update 5
They are in the latest 2009 Game Specific Drawings.zip file.
Should be here http://www.usfirst.org/uploadedFiles...20Drawings.zip
Unread 22-01-2009, 23:16
AKA: Randy
Re: Team Update 5
That zip file has 9036a and 9040. Not 9036B and 9040A, that's why I'm confused. The updated drawings have the old revs.
Unread 22-01-2009, 23:22
Engineering Mentor
AKA: Wally Ritchie
Re: Team Update 5
Hmm. I just loaded from the link and it has GE-09036_revB.
I believe the file name hasn't changed so you may have a browser cache issue. Make sure you refresh the page. Then try a save link as and specify a different name and see if that works.
Unread 22-01-2009, 23:48
AKA: Randy
Re: Team Update 5
Thanks, it was some sort of cache problem. Saving the link got the current file.
Unread 23-01-2009, 10:18
JesseK's Avatar
FRC #1885 (ILITE)
Re: Team Update 5
... not changed without both good reason and cogent explanation.
Heh, you're right, we win some, we lose some. I truly believe this update was to prevent trailer damage, which is part of the field as you stated. Damage prevention techniques are stated and implied in several spots of the manual (since Day 1) and on the Q&A.
Don't get me wrong though; I'm all for milling a 1/4" slot to allow for roll, which would prohibit pitch. I suppose we can call the GDC lazy for going with the simple method of drilling a bigger hole.
GitHub
Unread 22-01-2009, 23:12
AKA: Randy
Re: Team Update 5
Hitch Model showing Rev A and Rev B
Comes up as invalid attachment.
Team Update #2 Thexder General Forum 26 01-02-2008 12:56
Team Update #18 Ben Piecuch General Forum 114 23-03-2007 17:52
Team Update 19! Vincent Chan General Forum 3 26-02-2003 20:51
Team Update 18 Steven Carmain General Forum 10 25-02-2003 23:29
Team Update #3 is up pavelthegeek Rules/Strategy 8 24-01-2002 14:51
