Go to Post Please don't complain about the party that was thrown in your honor because they didn't use your favorite color of balloons. - Taylor [more]
Unread 21-01-2009, 12:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: How to attach wire to motors?
Originally Posted by jgraber View Post
Re "modification" vs "COTS unmodified status";
How are these usually judged?
Soldering to a solder lug, I'm guessing not count as mod.
Soldering to a spade lug, count as mod or not?
Cutting off a plastic shroud, does that count as modification?
If the shroud is removeable and replaceable, and we remove it, does that count as modification?
The stated intent of <R53> is "that the maximum power level of every ROBOT is the same" and "not to gain a weight reduction by potentially compromising the structural integrity of any motor". In particular, modifications to improve the interface between the motor and the rest of the electrical system would appear to fall under the spirit of <R53-C>, "The electrical input leads on the motors may be trimmed to length as necessary", as well as the clause allowing "teams to modify mounting tabs and the like". As always, only an answer on the Q&A can be considered official, but my assumption is that all of the modifications you describe are legal.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
How do you attach a pulley to extruded aluminum? Erich & Posse Technical Discussion 5 19-01-2008 15:34
How do i attach pictures? Captain Thunder CD Forum Support 1 22-06-2007 16:56
how to attach a carrier plate for a turret arm to the robot. vivek16 Technical Discussion 11 18-04-2007 11:16
wire size on the motors edthegeek Electrical 6 02-03-2007 08:05
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
