Go to Post While we discuss this stuff, let's keep our heads on straight. Open your eyes and look around you. Let's celebrate our common goal while accepting our differences. - Andy Baker [more]
Unread 20-01-2009, 21:29
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
Download code, restart robot, no work
we've managed to download the code and now it runs. but when we turn off the robot and turn it back on, it doesn't work. we keep having to repeatly download the code each time. we have heard about something called dependencies, could someone please elaborate more on this?
ok, who ate my hot pocket?
Unread 20-01-2009, 21:57
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: Download code, restart robot, no work
You're downloading the program to RAM, but you need to download it to flash to get it so survive between reboots. This can be done using the "deploy" option in FIRST downloader
Get yer robot source code here!
Unread 20-01-2009, 22:21
program1's Avatar
AKA: RJ
FRC #2441
where is the deploy option?
Unread 20-01-2009, 22:28
Hacker
If you're using windriver, it's under FIRST and then "deploy"
Unread 20-01-2009, 22:39
program1's Avatar
AKA: RJ
FRC #2441
unfortunately, we are actually using LABView, would you happen to know where it is?
Unread 20-01-2009, 23:29
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Explained here.
Making your LabVIEW application start when the cRIO boots
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 21-01-2009, 06:44
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
This question should be a FAQ.
Is there a FAQ?
Unread 21-01-2009, 13:14
guakam0li1089 guakam0li1089 is offline
FRC #1089 (Mercury)
Team Role: Communications
guakam0li1089 will become famous soon enough
after your done fixing any problems or such, go to robotmain.vi (in project explorer) right click and click build
Wise men talk because they have something to say; fools, because they have to say something.
Unread 21-01-2009, 14:12
BLAQmx's Avatar
Software Engineer
FIRST Community FAQs
Unread 21-01-2009, 20:34
program1's Avatar
AKA: RJ
FRC #2441
can someone explain where the robotmain.vi is, because in our project explorer, there isn't a "robotmain.vi" there is a "basic robot main.vi" but when i right click it, there is no option for build
Unread 23-01-2009, 10:08
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
what can cause a failure to deploy?
I build it, and when I click on set as startup, it fails at "Deploying FRC Basic Robot Deployment"
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 23-01-2009, 13:08
Don't right click the VI. Right click the thing at the bottom of the project explorer tree. (Without access to LabVIEW at the moment, I cannot remember the proper name for this thing.)
Cannot Download Code to our Robot jcvd C/C++ 9 27-01-2009 13:09
Can't Download Code nickmagus Programming 1 05-01-2009 17:52
How to upload/download the code from a robot? Team865 Programming 3 06-11-2007 17:03
2006 Robot Code Download Chris_Elston Programming 2 05-05-2006 10:42
Download code from robot Luminous Programming 4 25-05-2005 13:32
