Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Unread 21-01-2009, 15:14
Asmos's Avatar
Asmos Asmos is offline
FRC #2576
Asmos is an unknown quantity at this point
Question Problem with the joystick
Hello
I want to know if can you control two independets motor with only one joystick, programming with labview
can you please help me
Unread 21-01-2009, 15:32
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Problem with the joystick
I'm pretty sure you can! How exactly do you want to control them? Maybe a few more specifics would help us.
- Austin
EDIT - And welcome to ChiefDelphi!
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 21-01-2009, 15:43
Asmos's Avatar
FRC #2576
I was thinking that it can work, but does anybody know how to program it in labview?
Unread 21-01-2009, 15:44
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
As Austin said, yes you can.
To drive "Arcade style" (one joystick- X axis controls turning, y controls forward/backward) , simply wire the two axises up to the arcade drive subVI. To get to the axises, simply right click the joystick get subVI's axis output (NOT the button output), and click unbundle by name.
You can also control two non-driving motors in pretty much the same way. First you open the motor, then use the motor set speed subVI. If you want each axis to control a different motor, wire one up to the X, and one to the Y. If you want one axis to control two motors, wire both motors to the single axis.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 21-01-2009, 22:21
Asmos's Avatar
FRC #2576
thank you man, you safe my life
Unread 23-01-2009, 09:40
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Don't forget that you can also use the buttons to controll the motors if you have a fixed speed in mind. Also, with a little ingenuity, you can use different buttons to send different speeds to the same motor.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
can't get joystick right with the motor coolguybigt Motors 1 16-02-2007 10:20
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
