Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
Unread 19-01-2009, 17:42
Lucario231's Avatar
Lucario231 Lucario231 is offline
FRC #0033 (Killer Bees)
Lucario231 is an unknown quantity at this point
Question Labview Help: Sonar Sensor
Hi
I am trying to get sonar sensors working. I want to get it to read out the distance. When ever i have it wired correctly i flash it via run in labview nothing works and it freezes. I start with Ultrasound Open then ping then get range with all the required information for it to run.
What is the problem and has anyone else seen this problem??
Unread 19-01-2009, 18:37
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Re: Labview Help: Sonar Sensor
Did you add the sensor subvis to a project that you've already run on the cRIO? Did you open a reference before trying to get range?
Did you accidentally add a breakpoint in your code (do one of your subvis have a red border)?
A screenshot of the code would help.
Unread 19-01-2009, 18:39
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
This is a known issue. See http://forums.usfirst.org/showthread.php?t=10972
In short, GetRange.vi in the ultrasonic palette never returns if it doesn't receive an echo. The bug has been fixed for the next update, which will be released soon.
Unread 21-01-2009, 16:23
ringo115 ringo115 is offline
FRC #1647
ringo115 is on a distinguished road
what is our opinion on sensors, good idea or bad idea?
Unread 21-01-2009, 19:23
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
you need to make a custom sonar sensor code (i don't know specifically how we did it).
Sonar Sensor help eagleslg Programming 9 05-05-2008 21:14
SONAR Sensor Software Driver MikeDubreuil Programming 55 08-03-2008 11:03
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
