Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 20-01-2009, 01:54
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Question about bumbers and stuff about our chassis
Our team is planning on putting an angle on the corner of our robot. We are going to extend the bumper past the angle by roughly three inches from the adjacent side (http://www.whitebearlakerobotics.com...hassisplan.doc). According to our interpretation of the rules this is legal because:
* All bumper segments are 6” or longer
* We believe that our bumper configuration satisfies the <R08>-I requirements
We would like confirmation from FIRST on the legality of this configuration(but I have been having problems with the FIRST Q&A.
If this is deemed illegal we would like to put a bumper section on the piece of angle which extends into our robot base. Would this new bumper then be considered part of the bumper zone which nothing could extend over? It is anticipated that the overall configuration of our robot will be a four-sided polygon.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 20-01-2009, 02:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Question about bumbers and stuff about our chassis
The configuration shown is very similar to one side of 842's robot Carmen which the GDC has stated is illegal. The corner with the angle on it has no way of being protected by bumpers on both sides as required by <R08>-I and clarified in these two Q&A posts:
http://forums.usfirst.org/showthread.php?t=11159
http://forums.usfirst.org/showthread.php?t=11170
There appears to be no way to make the chassis shown legally.
Unread 21-01-2009, 12:59
Scott Hill Scott Hill is offline
FRC #1625 (Winnovation)
Scott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to behold
Cow Bell Solo, depending on where you put the pause in reading <R08> J, after "Corners" or after "joints" (GDC, a comma would have been nice), you may not be able to have the filler projection past the lower right corner of the robot as you show in your sketch. J can be read to conclude that such fillers can only be used to fill the space between bumper segments. If you remove the questionable filler projection I think you would be legal with respect to perimeter bumper protection. Both sides of the robot relative to the corner are protected by bumpers and you also meet the following: (from <r08>) ... If implemented as intended, a ROBOT that is driven into a vertical wall in any normal PLAYING CONFIGURATION will always have the BUMPER be the first thing to contact the wall." This sentence is the one most comprehensive and unambiguous metric the game manual includes regarding required scope of robot perimeter bumper protection. In my humble opinion many of the discussions which do not include this item seem to be doing a lot of tail chasing and are doing more to confuse the issue than clarify it.
Unread 21-01-2009, 13:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
the image as an image file
I agree with Vikesrock. I think <R08-I> gets you...when combined with the Q&A answer....
I. BUMPERS must protect all exterior corners of the BUMPER PERIMETER (see Figure 8 -
2).
2. As indicated in Rule <R08-I>, all exterior corners of the BUMPER PERIMETER must be protected by BUMPERS. Both "sides" of the corner must be protected.
Of course our opinions aren't the Q&A...
Unread 21-01-2009, 15:52
No Stolte No
AKA: Chris
Thank you for your responses and We are changing our design of our chassis based on this, We are just going with our backup design. Good thing for planning!
Unread 21-01-2009, 16:06
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I don't know, I think you could argue that the interior angle part of the bottom right corner of the bot is technically protected by the flat part of the bumper on the left half of the bottom face in the picture. There isn't a way for an opposing bot to come into contact with that corner.
Unread 21-01-2009, 16:15
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Please explain to me how this corner is different than one of the front corners of 842's robot which the GDC has specifically said cannot be legally protected?
Based on previously provided information, you have correctly concluded that all exterior corners must be protected by BUMPER segments (Rule <R08-I>). Each BUMPER segment must be a minimum of six inches in length (Rule <R08-A), and must be attached to the BUMPER PERIMETER (Rule <R08-L>). Effectively, this means that an exterior corner of the ROBOT can not be at an angle that is more acute than the coincident corner of the BUMPER PERIMETER. It follows that the example configuration you cited would not be permitted.
The corner in the bottom right of the posted drawing is more acute (45 degrees) than the coincident corner of the bumper perimeter (90 degrees).
At this point with the exception of what "frame" needs to go behind the bumpers I feel the GDC has expressed the intent of the bumper rules in a pretty clear manner. If teams choose design around thier lawyering of the rules and completely ignore the Q&A, they should prepare to be burned. I don't mean to sound like a jerk here, but if a robot with angled intake corners like this passes inspection at my teams regional I will bring most certainly bring these Q&A posts to the Head Inspector's attention and make certain that the team must bring their robot into compliance before competing.
Unread 21-01-2009, 16:41
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Since everyone has determined that we are illegal we are changing our bumpers. Just kidding, we like the critques. It helps us develop our design. We now feel that we will loose that battle so we are changing.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 21-01-2009, 16:48
hillale's Avatar
AKA: Alec Hill
I will agree with you Vikesrock, I'm just curious as to why they seemingly avoid stating that each side of a corner must have 6" bumpers ATTACHED to it at all costs.
Unread 21-01-2009, 16:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Heh, sorry to keep dragging you guys into all these bumper thread, but your posted chassis design is a great example that the GDC has ruled on directly.
Like this?
I agree that it should be in a Team Update to spread maximum awareness, but they have definitely said it.
Unread 21-01-2009, 16:56
hillale's Avatar
AKA: Alec Hill
Originally Posted by Vikesrock View Post
Like this?
That's exactly what I'm talking about, protected by and having physical bumpers attached mean 2 different things to me.
Question about digital inputs and outputs Torboticsmember Electrical 2 12-02-2007 22:51
Question about Solenoid and default code waialua359 Control System 4 21-01-2006 18:21
Tech Question About CAD and RP indieFan Chit-Chat 2 23-07-2004 12:35
One last question about our code dddriveman Programming 5 22-03-2004 09:49
Question about Gas Springs on SPI (CD, u guys used this stuff!) Anton Abaya Technical Discussion 5 05-02-2002 21:55
