Go to Post We all need to keep things in perspective. When you look back at the entire 2005 FIRST season, is your entire experience defined by the presence of a little cloth flag on the play field? - dlavery [more]
Unread 21-01-2009, 17:51
spacegy4's Avatar
spacegy4 spacegy4 is offline
Is a CAD
AKA: Andrew Sternglass
FRC #0639 (Code Red Robotics)
spacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to all
Send a message via AIM to spacegy4 Send a message via MSN to spacegy4 Send a message via Yahoo to spacegy4
Regarding Rule<R08> part M(Bumper attatchment)
Is supporting the bumper along its length sufficient or does it also need to be supported on all 4 sides. We'd like to attach it with a row of screws to a 1" square extrusion running the length of the side of the robot.
Thanks-
Spacegy4
Team 639 Code Red robotics
Unread 21-01-2009, 17:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Regarding Rule<R08> part M(Bumper attatchment)
Thanks-
Spacegy4
I'm confused, how would you legally support the bumper on all four sides? Anything supporting a part of the bumper other than the back would be the farthest outboard part of your robot and thus define your bumper perimeter which your bumpers would no longer be sitting on.
Your method of attachment sounds like it should satisfy the rule. I would suggest avoiding screws however as they will make it more difficult to attach and remove your bumpers,
Unread 21-01-2009, 18:01
spacegy4's Avatar
Is a CAD
Sorry we mean all 4 sides of the robot.
We would only be attaching it along the length of the robot.
Unread 21-01-2009, 18:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ok, I think I get what you're saying. I will try to answer generally so you may get your answer even if I have the wrong idea bout what you mean.
There are two issues at play here.
1. <R08>-M states that a bumper must be fully back along it's length. This means that every bumper segment on your robot must have a structural backing along the entire length of the plywood portion of the bumper.
2.<R08>-I states that all exterior corners of your robot must be protected by bumpers. The GDC has clarified through the Q&A that this means that both sides of the corner must be protected.
Taking these two rules together, barring atypical designs like corners that are very round (and may avoid being "corners") or sides less than 12" long it would appear that you need at least 12" of bumper with a robot structure behind it on each side of your robot.
Unread 21-01-2009, 18:18
spacegy4's Avatar
Is a CAD
It would really help if I could know if structural backing meant structural as to maintain its strength or structural as in made part of the robots main structure.
Unread 21-01-2009, 18:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This would help everyone
For now, this is what we have (in addition to the rule itself):
http://forums.usfirst.org/showthread.php?t=11349
No. The intent of Rule <R08-M> is to ensure that sufficient structural reinforcement is provided to the BUMPERS to allow them to withstand the high-speed, high-energy impacts that are likely to occur during a typical Lunacy MATCH without failing. A simple flat 1/8-inch aluminum plate mounted on standoffs is unlikely to provide the required structural support for the BUMPERS.
Does <R08> prohibit above-bumper extension? BethMo Rules/Strategy 12 07-01-2009 09:20
FIRST rule regarding team membership eagleslg General Forum 22 26-11-2008 20:59
Bumper Rule Compnerd Rules/Strategy 24 19-01-2008 08:24
Rule <R08>, weight of upgrade parts Gary Dillard Rules/Strategy 6 11-02-2005 11:16
Bumper Rule <R17> Veselin Kolev Rules/Strategy 10 23-01-2004 09:58
