Go to Post We do a disservice as mentors if we simply complain. We must inspire our students by showing them how we rise to the challenge and solve the problems we face. - Jon236 [more]
Unread 21-01-2009, 18:40
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: Cannon Design!!!!!! >_<;
It is possible that the wheel is not wide enough to power the moon rocks well, but there are a number of other possibilities.
As Eric mentioned, this type of mechanism works the best when the wheels are already spinning and then the ball is fed into them.
Another potential issue is compression. Based on what teams have been reporting here and what my team has seen in very limited testing you want at least an 1" of compression at the narrowest point between the two wheels meaning they should be 8" apart at the most. You also don't want more than about 2" of compression so they should be at least 7" apart.
The last potential issue results from the drills. If the drills are not providing enough speed or torque or both your design may not work well. If the wheels are not spinning fast enough they will not transfer enough energy to the ball as it passes through. If the drills don't have enough torque, the wheels will slow down too much as the ball passes through and the wheels will then not transfer enough energy to the ball.
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Air Cannon Rob2713g General Forum 40 27-05-2009 21:15
ball cannon??? stinkypooman General Forum 142 06-03-2009 13:48
air cannon Evil Asian General Forum 10 15-03-2007 10:31
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
