Go to Post Make sure you THOROUGHLY understand the rules of the game before you actually start designing the robot. - Koko Ed [more]
Unread 21-01-2009, 19:03
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Semaphores and Synchronized's
The C_CPP_Programming_Guide.pdf talks about semaphores, but it does not give examples, could some one give me an example?
Watchdog.Kill();
Unread 21-01-2009, 19:15
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Semaphores and Synchronized's
Search through the WPILib sources, there are a few examples there.
Unread 21-01-2009, 19:19
byteit101's Avatar
Where are the sources?
Watchdog.Kill();
Unread 21-01-2009, 19:31
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
http://first.wpi.edu/Images/CMS/Firs...1562Source.zip
Unread 21-01-2009, 19:32
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Sorry if this is a double post.....
Unread 21-01-2009, 19:41
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
I think its pretty much like error in and error out. But im not sure
Unread 21-01-2009, 19:59
byteit101's Avatar
and what is a SEM_ID?
(I have gotten this so far:
Synchronized s(???);
Watchdog.Kill();
Unread 21-01-2009, 20:03
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Huh?
Unread 21-01-2009, 20:33
byteit101's Avatar
Huh?
You call semTake(semaphore id, wait time), the resource is locked, and then you release it by semGive(semaphore id);
I am trying to find out what the id is and how to create/get one
Watchdog.Kill();
Unread 21-01-2009, 20:53
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Semaphores basically prevent critical regions from executing at the same time. The Synchronized class basically handles semGive() and semTake() automatically. To mark the start of a critical region, you use the macro CRITICAL_REGION(semID) and END_REGION, which automatically wraps the area of code in a Synchronized class. To create a semaphore ID, simply declare a SEM_ID. Any critical regions that you do not want to run at once should share the semaphore ID. No further configuration of the semaphore ID is needed unless you want to use an advanced type of semaphore (such as a counting semaphore). More information can be found here:
http://www.slac.stanford.edu/exp/gla...ef/semLib.html
Unread 21-01-2009, 21:08
byteit101's Avatar
slavik262, Thanks for the explanation, but i knew that from the C_CPP_Programming_Guide.pdf.
I did some more looking about, and I found the Answer:
//Top of file after includes
SEM_ID robotLock = semMCreate(SEM_Q_PRIORITY);//this creates a lock for the use of myRobot
//in a function somewhere else
		CRITICAL_REGION(robotLock);
		myRobot.Drive(1.0,0.0);
		END_REGION;
the robotLock variable is the lock that needs to be obtained for a safe procedure, but it is not neccesary. So someone could do this:
		END_REGION;
//more code and other functions of a very complex nature here
myRobot.Drive(0.5,0.0);//this will compile but be not safe
So you need to explicitly obtain a lock for the variable you want and have decided to use for it.
Thanks for everyone's help in leading me to the right answer
Watchdog.Kill();
Unread 29-01-2009, 23:43
Phazonmutant's Avatar
Phazonmutant Phazonmutant is offline
Winrar
AKA: Greg Mitchell
FRC #2556 (RadioActive Roaches)
Phazonmutant is on a distinguished road
I've never worked with multithreading before; what would be some example uses of having multiple tasks that might both need to access data?
Unread 31-01-2009, 12:37
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Well Maybe you could have a thread that takes all the info from the camera, or some other processor intensive task and put it into a thread. Then you could use a semaphore to lock out the angle offset, or some other data. Then when the main thread goes to access the data when it is being written to by the seperate thread, you wont get invalid data because it is only half written to.
Unread 31-01-2009, 22:27
byteit101's Avatar
or, as we are using, a safety feature, press button 11, on thread 1, and it stops the motors for driving. though you dont have to use threads for that, but we thought it might be easier
Watchdog.Kill();
Unread 02-02-2009, 17:26
Jared Russell's Avatar
Taking a year (mostly) off
If you want to get fancy, you can also look into the "semBCreate()" and "semCCreate()" functions. They offer slightly more advanced variations of the simple mutual exclusion semaphore.
Bill of Materials, do it and do it well, and bring it to your event sanddrag Rules/Strategy 3 24-03-2006 21:09
pic: Stars and Stripes over Einstein and Galileo CD47-Bot Extra Discussion 6 01-05-2004 00:54
