Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 21-01-2009, 19:23
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
pic: 148 Follower Wheel Assembly
Unread 21-01-2009, 19:24
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: pic: 148 Follower Wheel Assembly
Totally unnecessarily awesome...
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 21-01-2009, 19:30
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
How is this going to measure ground speed if it can't touch the ground?
Mens et Manus
Unread 21-01-2009, 19:32
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
It can.
The GDC has ruled that similar devices do not count as "traction devices" in the Q and A.
Unread 21-01-2009, 19:33
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
It was asked in the Q&A and they said that if it does not provide traction than it can touch the ground. The actual rule says that the rover wheels are the only thing that can provide traction, not the only thing that can touch the ground.
Team 968 (Mentor) 2011
Team 1138 (Mentor) 2010
Team 1138 (Student) 2005-2009
Unread 21-01-2009, 19:34
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I'm no mechanical engineer (no, really, I'm not) but I'm assuming this will either touch the KOP wheels or somehow be attached along the route of the chains, without touching the ground.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 21-01-2009, 19:43
NoahTheBoa's Avatar
FRC #0968 (RAWC)
Here is a relevant Q&A on the subject
Question:
Can any part of your robot...other than the FRC supplied wheels...make contact with the playing surface if their intention is not to provide traction to propel or stop the robot?
GDC:
Yes.
http://forums.usfirst.org/showthread.php?t=10919
Unread 21-01-2009, 19:45
We were planning to do the same thing, but with all vex components, including the new encoders. Hadn't gotten to it yet.
Unread 21-01-2009, 19:55
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Fabulous use of VEX parts in a very elegant package. I think we'll be seeing a lot of similar assemblies this year.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 21-01-2009, 19:56
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Humm - how much bigger than the green gear is that omni wheel? The reason I ask is because on the carpet, the wheel may sink in enough to allow the gear to grab some carpet fibers.
Also, is it just pivoting off the robot frame from that empty set of holes, and thus using gravity to keep it in contact with the floor?
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 21-01-2009, 19:59
NoahTheBoa's Avatar
FRC #0968 (RAWC)
If you are just using gravity to maintain contact with the ground have you tested to see if it slips at all when driving on the regolith?
Unread 21-01-2009, 20:03
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Beautiful assembly!
Have you tested whether it will stay on the ground under its own weight? If not, may I suggest gas springs!
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 21-01-2009, 20:24
Correct me if I'm wrong, but are those delrin sideplates? They look very nice. Good luck with this. =)
Unread 21-01-2009, 20:26
REVving up for a new season
FRC #2848 (All-sparks)
I like the fact that black gear is an ABS rapid prototype. Want to clue the world into the right pitch for interfacing with a vex gear?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 21-01-2009, 20:35
AdamHeard's Avatar
Lead Mentor
Soo.... will Vexlabs be selling these?
We had a similar plan, and were thinking if gravity wasn't sufficient, a rubber band to add a slight amount of tension would be easy enough.
pic: Team 148 Engineers Brandon Martus Extra Discussion 9 16-02-2009 23:08
pic: 148 Puncher JVN Extra Discussion 13 12-04-2008 00:04
pic: 148 + 217 = 128 Richard Wallace Extra Discussion 8 04-03-2007 17:42
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
Image Discuss: Team 25 modular gearbox and modified wheel assembly CD47-Bot Robot Showcase 6 10-02-2003 20:02
