Go to Post If you cannot complete relatively simple tasks, why would anyone assign you something more challenging?? - Chris Fultz [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 21-01-2009, 20:18
jujuninja's Avatar
jujuninja jujuninja is offline
AKA: Dakota
FRC #1569 (Haywire)
Team Role: CAD
jujuninja is an unknown quantity at this point
C-Base
Hey does any one have the C-Base that they made from the ground up. that i can edit.
Kit Of Parts: $6,000
Buy Food for Those Late Nights: $150
Paying for the bus ride to Atalanta: $400
Loving the Blood, Sweat, Tears for Being On a F.I.R.S.T. Robotics Team: Priceless
e
Unread 21-01-2009, 21:04
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: C-Base
This isn't really from the ground up, but the AndyMark step file is what we are using in the TechnoKats. You can edit it and use it in Inventor, Solid Works, and any other application that has .stp support.
http://andymark.biz/am-0205.html
Go to that page and scroll down almost all the way and you can see that there are two files to choose from, the long and the wide base. Make sure to right-click save as. Also if you want this to make your own variation, I would just copy one of the long c-channels then cut it down as the entire base is made from 4 parts (without the gearbox or wheels).
I win! XD
Unread 21-01-2009, 21:23
jujuninja's Avatar
AKA: Dakota
FRC #1569 (Haywire)
Team Role: CAD
Re: C-Base
i have that b ut i can edit the part.
e
Unread 21-01-2009, 21:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: C-Base
The quick and dirty way (but probably not the "right" way) to cut the rails from the .stp down is to sketch a rectangle bigger than the C-channel over the area you want to cut off, then extrude-cut it through the whole part.
Unread 26-01-2009, 16:24
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Re: C-Base
The Cbase is over on Content central at solidworks. You have to register to download it, but it contains all of the base parts, c channel, corners, bolts, wheels, motor mounts maybe more.
We just took it apart so we could use the parts to make it fit our design. It works well.
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 28-01-2009, 13:52
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: C-Base
This is the link to the andymark short C channel
http://www.3dcontentcentral.com/secu...d=171&id=13570
You can insert a cut feature to remove the material you dont want. Remember what side you are cutting because the holes are not symmetric on the front face.
You can also edit the first feature sketch, but the sketch is fixed - so delete the relations and then add dimensions.
Let me know if you need help. Marie
Unread 24-05-2014, 17:33
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
Team Role: Electrical
BryceKarlins is on a distinguished road
Re: C-Base
New C-channel Model on 3D Content Central:
http://www.3dcontentcentral.com/secu...=171&id=125932
Code Base 3DWolf C/C++ 3 19-01-2009 16:48
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
Knowledge Base Leon Machado IV Programming 15 02-08-2005 12:24
Delphi Base archiver 1999 0 23-06-2002 22:03
