Re: pic: 2013 gnomes robot sneak peek
I could be off, I just guessed some general dimensions and assumed .5lbs a foot. I think its like .51 pounds a foot. Since its welded you dont have all of those brackets whose weight adds up.
What about torsional rigidity from one 'front' wheel to the other? I am thinking the welding is a lot stiffer than conventional joining (screws) but I'd like to hear what you have found.
JK |
hmm, just curious... How do you plan to slide the little screw holders into the t slots?
Also, if you were goign to weld it like that, why not just use 1x1x1/8 aluminum square tubing? |
1x1x1/8 aluminum weighs almost the same at the 10 series (1x1) 80/20, don't believe me? ask any of the kids on 73 from the 2007 season. I was skeptical also bu proven wrong. As for the t-nuts, there are many styles of them, many can be inserted into the rails not from the end. 80/20 PN 3376 is one of them. |
You cut slots and slide them in, but be sure that you dont make a slot where you need to mount something though.
#7
that looks cool
#8
Geez, looks like some teams took it a little more seriously than others when they cautioned to design our robots to take a hit... Pretty sure you could get in a wreck with a hummer and come out alive. How much did that thing cost? We panicked when we had to buy like 24' of it for our forklift last year (and we did some darn good innovation just to eliminate the need for 2 more pieces of the stuff).
#9
SHENANIGANS!!!
Your building a miniature Y-Wing!!! If my bot is hit with a proton torpedo i am going to be so mad |
#10
Looks very heavy for the DT.
#11
allright, forgot to tell you guys: its 29 pounds
#12
Expecting land mines on the field?
..I guess they could just have a light manipulator and decided a beefy frame would be nice to have. ..Interesting nonetheless. -Greg |
| pic: Sneak peek at 09 controller | Pjohn1959 | Extra Discussion | 1 | 20-04-2008 22:23 |
| pic: intelitek's present to you.....a sneak peek at easyC PRO! | Jessica Boucher | Extra Discussion | 22 | 02-01-2007 14:06 |
| pic: Sneak peek Team 858 Delphi Demons | CD47-Bot | Robot Showcase | 3 | 02-02-2004 16:43 |
| Sneak Peek | Stormhammer | Robot Showcase | 1 | 20-01-2004 15:35 |
| vB 3.0 - Sneak Peek | Brandon Martus | CD Forum Support | 13 | 30-06-2002 23:38 |
