Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 21-01-2009, 21:24
Questions4mQ202 Questions4mQ202 is offline
FRC #2348
Questions4mQ202 is an unknown quantity at this point
Reading Encoders?
There were many posts that were very useful regarding how to wire up the encoders (I believe, they were Andy Mark). But before we get into the fun stuff of splicing the wires, our adviser insists that we figure out how to read its output values, so Programming can do their job. Would anyone happen to know how we can test this?
Thanks much in advance!
Unread 21-01-2009, 21:53
elcron elcron is offline
Programmer
FRC #0348
elcron is an unknown quantity at this point
Re: Reading Encoders?
Are you using labview or C++?
If Your using C++ wpilib has an encoder class.
PHP Code:
Encoder *= new Encoder(12); //1 & 2 = your dig io pins for channel a & b
e->Start();
int distance e->GetDistance();
// use distance for whatever you want
Unread 21-01-2009, 23:03
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
The output values are easy to read. But they can be done only once you splice up the wires. I suggest you probe it on to a Oscilloscope and look at the quadrature signals. As you ramp up the motor, the signals should come closer to each other. If there's not a ton of noise, and if it looks "alright" then you should splice it. I wish they gave us two PWM outs instead of 1 4-lane cable.
Once you splice it and connect the correct A & B ports, then it's really simple, just go to WPI Libraries -> Sensors -> Encoders and do the usual thing with Open, Get, Close. Though, this time, you may want to fiddle around with the Configuring the Timers.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 23-01-2009, 19:19
drkiraco drkiraco is offline
FRC #1747
drkiraco will become famous soon enoughdrkiraco will become famous soon enough
It's pretty easy in labview. There's an encoder vi in the library. Just tell it what digital IO pins you've connected it to and that's all there is to it.
Unread 23-01-2009, 20:51
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
how accurate are your encoders? Our mentor says 1 of the values wasn't returning that well...
I think he said it know the distance but not the rotations or something...
Also do these break easy? im guessing we should have extras?
Unread 23-01-2009, 22:22
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
The encoders do not return the correct value for rate.
Here is the announcement of the bug:
http://forums.usfirst.org/showthread.php?t=11343
Here is the thread that isolated the bug:
http://forums.usfirst.org/showthread.php?t=11004
Unread 23-01-2009, 22:27
AKA: Dani
ok so reading through the isolated thread, dont really see how to fix the issue...
sorry just clarify what you meant, isolate as in just push the problem aside? or isolate as in fix the rate problem?
Unread 23-01-2009, 22:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
By "isolated the bug" he means that it discovered the source. As indicated in the first thread that he linked to the bug is going to be addressed in the next software update.
Unread 23-01-2009, 22:41
AKA: Dani
ok thanks a lot.
Unread 23-01-2009, 23:51
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
does anyone know when the next update will be coming out?
Unread 24-01-2009, 22:23
Jared Russell's Avatar
Taking a year (mostly) off
I hope soon for our sake!
Unread 25-01-2009, 01:57
AKA: Randy
It went beta the first of last week - I thought it was going to be released by the end of the week.
Unread 25-01-2009, 20:28
The thread on the FIRST forums suggests a new update will be out tomorrow (Monday). The issue should now be resolved.
Unread 25-01-2009, 20:47
AKA: Brad
#0190 ( Gompei and the Herd)
It's supposed to come out sometime tomorrow (Monday) and the encoder problem is fixed. If you were just reading distance or the count, that has always worked. The problem was just with reading the period or rate.
Brad Miller
Robotics Resource Center
Reading Interrupt Ports ManicMechanic VEX 3 26-06-2008 12:43
Books Worth Reading Mr.D Chit-Chat 2 24-01-2006 13:50
Bathroom Reading Eugenia Gabrielov Chit-Chat 28 15-04-2005 17:49
reading rainbooooow! Nelly51987 Chit-Chat 22 15-05-2003 13:55
Time reading ChiefDelphi Wetzel Chit-Chat 23 28-02-2002 06:45
