Go to Post I think there are a ton of teams that would kill for one let alone three engineering mentors (especially one with the knowledge and experience that Rich Olivera has). - XaulZan11 [more]
Unread 21-01-2009, 22:07
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Gear Tooth Sensors
Are we allowed to use the Gear Tooth Sensors provided by FIRST two years ago on this year's robot? Rule R32 says we can't use FIRST custom made parts from previous years, but I don't know if the sensors are included in that.
Compiling...
Compiling...
Unread 21-01-2009, 22:12
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Gear Tooth Sensors
The question to ask is, can you buy the exact same thing somewhere? If yes, it is a COTS part. If not, it is not and can't be used. I believe the latter (= no) is true, but I ask others to also comment.
BTW, you can buy the sensor and build your own.
Don
Unread 21-01-2009, 22:15
Thanks for the speedy reply. As it were, we were hoping to get sensors soldered and ready for testing before friday, so ordering additional parts is an undesirable option. If anyone can recommend any Gear Tooth Sensor solutions, please speak up...
Compiling...
Compiling...
Unread 21-01-2009, 23:29
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We used these last year. They run off of 5V instead of the 5 and 12 that the FIRST sensor boards needed. They are open collector so you have use a 4.7K pullup resistor on the output signal.
http://rocky.digikey.com/scripts/Pro...480&M=1GT101DC
Here's a thread with pictures on how they can be mounted:
http://www.chiefdelphi.com/forums/sh...ad.php?t=62083
Brian K
Team 1225 Robotics Mentor
DonRotolo's Avatar
Back to humble
FRC #0832
If you are using the toughbox from the KoP, or can somehow get a 1/4" shaft to turn with whatever you want to turn you can use the encoders supplied in the KoP this year.
You can use a photo-interrupter. There are two interrupters inside a ball-type (old style) mouse. Radio shack sells an LED / Photo-diode set that can be used. Just shine the light beam from the interrupter through something that interrupts the beam (like the teeth of a sprocket, a piece of chain from above, a special-built interrupter wheel, spokes of a KoP wheel, etc.)
Interrupt Gear Tooth Sensors NinJA999 Programming 3 04-02-2008 20:33
gear tooth sensors purchasing wedellm Motors 5 07-02-2007 20:50
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
