#16
Re: pic: 148 Follower Wheel Assembly
But it would be one anal inspector to call you for that ![]() |
#17
Edit: Yup, they're 24 DP. Last edited by artdutra04 : 21-01-2009 at 21:10. |
#18
wow JVN this looks VERYYYY familiar....ours looks almost identical...
#19
I think that since it's an omni wheel the sideways friction won't be enough to slow a 120 lbs+ robot.
#20
Very nice! But why such a big green gear? I'd have used a smaller gear and a similar green gear on the encoder. I am curious.
Also, I think we'll be stealing the idea! (kinda sorta) Thank you! Don |
#21
It looks to me like it's a 1:1 ratio. Would make programming a bit easier without the extra math to account for the gear ratio.
#22
How much would you pay for one? I'm starting my own company KarthikJohn.Quote:
The side plates are laser cut ABS, 1/8" thick (cut on our small 12x24" laser, not the big one that does the sheet-metal.) The coupler is 3D printed ABS on our Dimension SST. I feel pretty darn spoiled. Probably could have gone with a smaller package, but we've got plenty of room in the drivetrain to mount it. Like Raul said, if the 60t gear catches some carpet we may change it. I'm not real concerned. *Shrug* This was done quickly and the design group moved onto other things. -John |
#23
Why not use the larger omni wheel? It would get the wheel away from the gear more. Also the larger omni probably has a less likely chance of slipping...
#24
This year the encoder models... but thanks for a good 2010 plan.
#26
Not counting the cost of the encoder, I'd say $25-30 probably.
#27
Ditto on this. With encoder, depends on the accuracy/type of the encoder.
#28
Looks strikingly similar to something we're making...
#29
Where would you put this company? Halfway between Toronto and Greenville is...I dunno...Kokomo?
#30
With a few modifications you could use the US Digital encoders that come in the kit.
| pic: Team 148 Engineers | Brandon Martus | Extra Discussion | 9 | 16-02-2009 23:08 |
| pic: 148 Puncher | JVN | Extra Discussion | 13 | 12-04-2008 00:04 |
| pic: 148 + 217 = 128 | Richard Wallace | Extra Discussion | 8 | 04-03-2007 17:42 |
| pic: 885 Right-center wheel and drive assembly | CD47-Bot | Robot Showcase | 2 | 30-04-2004 18:27 |
| Image Discuss: Team 25 modular gearbox and modified wheel assembly | CD47-Bot | Robot Showcase | 6 | 10-02-2003 20:02 |
