Go to Post Just to be clear, NOTHING anyone says here is a confirmation. The ONLY source for official answers to questions like this is the FIRST Q&A system. - dlavery [more]
Unread 22-01-2009, 02:08
hellochar hellochar is offline
FRC #3006
hellochar is an unknown quantity at this point
Bluetooth with cRIO/DS?
I want to use the accelerometer in a wiimote rather than the one given in the KoP because our readings are very jittery. I've already successfully connected the wiimote to my home PC that's using a 3rd party Bluetooth dongle, with an installation disc provided.
What I want to know:
Is it possible for me to install that 3rd party software onto the cRIO, and to plug the dongle into one of the USB ports in the DS, so I can retrieve accelerometer values from the Wiimote?
I know this is probably a stretch; the biggest problem is getting the 3rd party installation into the cRIO. Any suggestions would be appreciated. I just thought up of this a few days ago and I'm going in tomorrow to try and test things.
Unread 22-01-2009, 04:19
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Bluetooth with cRIO/DS?
What you described isn't technically possible, and the rules prohibit other wireless communication devices on the robot or DS.
Eric Haskins KC9JVH
Unread 22-01-2009, 14:38
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
While you are not allowed to use Bluetooth for this, what you could do is connect a Wii Nunchuck to the cRio via the I2C port. If you search online, you should be able to find several sites which describe the data format, which looks pretty straight forward. I haven't used i2c anywhere myself, but if you search the forums here and the cRio documentation, you should find instructions on how to use i2c.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 22-01-2009, 17:20
FRC #3006
Whoa, now that is cool. Thanks!
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
Bluetooth!?! Chath Maral Programming 10 10-01-2009 14:39
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
Who is Programming the cRIO with C++ and what success are you having? Wayne C. Programming 20 01-01-2009 16:48
pic: cRIO Model with I/O Modules in Inventor Ed Sparks Extra Discussion 5 22-12-2008 22:17
