Go to Post Check Chief Delphi, and if there isn't a post, make one. - sithmonkey13 [more]
Unread 21-01-2009, 21:15
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Driving on carpet
Originally Posted by Hazmatt View Post
Will this be counted as an extra traction device?
Well if it does, All teams will be illegal for increasing the traction!! Fun game when no one's playing since we're all illegal! haha!
Unread 21-01-2009, 21:26
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
So the wheels are stripping electrons off of the ground and giving the chassis a negative charge while leaving the ground positive. The opposite charges will then attract thus increasing the force of the robot on the regolith. Will this be counted as an extra traction device?
if my understanding of electricity is correct,
it should be the other way around
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 21-01-2009, 21:33
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Originally Posted by CraigHickman View Post
Shouldn't be a problem. Our 06 bot turned out to be an unintentional Van De Graph generator, so we could get a HUGE jolt by touching the frame after any match. Lucky we had a crazy freshman who kinda liked it!
Same for us in 06. Hooray for freshmen!!
Unread 21-01-2009, 21:34
The rule that requires the camera and CRIO be insulated is to prevent interaction between robots that might cause electrical issues since both of these devices have a connection between the case and negative power supply. The static discharge that most teams experience may or may not cause problems with your robot. Teams in the north during winter experience low humidity from the heating during the cold months which makes matters worse. Humidty tends to draw off the charge. Dragging an electrical anchor (wire, braid, etc.) likely does very little since the driving surface (carpet or regolith) is an insulated material. Please be advised that high impedance sensors are the most vulnerable to static discharge but anything on the robot can be affected. We have found that certain electronic potentiometers are overly sensitive to static. If you are using these devices and have an issue during static discharges, I would recommend a change of component design to something more fault tolerant. I would predict that as much static builds up as the insulated wheels are turning near metal robot frame parts as is picked up by the robot moving across carpet.
Unread 21-01-2009, 22:29
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by wilmo View Post
I don't believe it will be a problem either, since most teams mount their electronics on lexan/polycarbonate, no additional precautions are really necessary.
Um, I beg to disagree. Touch some electronics (see ASl's post above) and the static discharge will damage it, either 'walking wounded' or outright failure.
The solution is almost trivial though: ALWAYS (always always) touch the metal chassis before touching anything else. This will discharge any static and render it mostly safe.
The "correct" way is to wear a static discharge strap (buy one, don't make one, they have resistors in there...) and connect THAT to the robot metal before doing anything. Straps like that are under $5.
Thise metal foil-like plastic bags? Yep, those are used to protect static-sensitive items in shipping. ANYhting that came in one is sensitive to static and you really, really ought to follow the right procedures.
Don
*Walking wounded: You have damaged a semiconductor in such a way that it will fail very soon, but works OK at the moment.
Unread 21-01-2009, 23:05
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
you guys should all check out and read Team Update #5
its all about the electro-shock concerns and how to deal with it.
http://www.usfirst.org/uploadedFiles...Update%205.pdf
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 21-01-2009, 23:25
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I don't see what everyone's problem is we've been driving around fine and haven't been shocked at all. We discovered the solution: wooden axles We've found balsa wood to be the best choice.
But I do agree just touch the chassis before anything else...or find a freshman to do it for you.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 22-01-2009, 07:24
Walking Wounded...
def. A semiconductor about to give it's life to protect a breaker.
Carpet Renegade General Forum 7 06-04-2006 01:33
Carpet atmaturen General Forum 3 28-12-2004 12:36
Carpet??? Mandy_Candy General Forum 3 14-02-2004 10:35
Carpet? archiver 2000 2 23-06-2002 22:33
carpet friendly? sidewinder Off-Season Events 1 11-11-2001 07:06
