Go to Post I have always gotten the answers I need. They're just not always the answers I want... - Alan Anderson [more]
Unread 22-01-2009, 08:25
Re: How to attach wire to motors?
The FP motors are difficult for several reasons. Soldering is the best but there is a temperature controller within the motor (I have not verified this for this years KOP yet.) and too much heat during soldering will damage it. The end plate ofr the motor is also the brush holder, so if you heat it too much, brush alignment can be affected. The FP motor uss a smaller version of the push on connectors available in most hardware stores. Digikey does sell the right style however. If you are good at soldering and feel comfortable undertaking this task, be aware that the terminals on the motors do have a protective coating that is displaced by the push on connectors. Cleaning and scarping make soldering a much easier (and quicker) task.
How do you attach a pulley to extruded aluminum? Erich & Posse Technical Discussion 5 19-01-2008 15:34
How do i attach pictures? Captain Thunder CD Forum Support 1 22-06-2007 16:56
how to attach a carrier plate for a turret arm to the robot. vivek16 Technical Discussion 11 18-04-2007 11:16
wire size on the motors edthegeek Electrical 6 02-03-2007 08:05
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
