Go to Post There is always more than one way to design something. - Dave Scheck [more]
Unread 22-01-2009, 08:31
Re: Wiring LED to Driverstation
Originally Posted by sircedric4 View Post
So to repeat I go from red 5V from digital output through my LED and then to the signal pin on the digital output? Is this correct? And then my program can turn it off and on by cycling the digital output in code?
It will work that way, though the LED will be off for a "1" value and on for a "0". Since the DS's output can source current as well as sink it, I'd connect from the digital output through the indicator to ground instead. That way the LED will be off for "0" and on for "1".
The way you connect it should depend on whether you want the LED to be on or off when the system is reset, before the cRIO software has a chance to control it.
Unread 22-01-2009, 09:21
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
I originally tried it this way, from the center pin (indicator, signal) through to ground in the direction where the signal wire went into the positive side of the LED and it didn't do anything when I commanded it to. I thought I was just wiring it wrong. I may have to check to make sure the PWM cable was hooked to the correct pin. Couldn't FIRST have bothered to label their pins, its so easy to miscount!
Thanks everyone, I imagine with the info here I can get it to work. I'll let you know after I get a chance to try it tonight. I can't exactly bring the control system to work so have to wait till the evening to play with it.
Unread 22-01-2009, 10:05
I originally tried it this way, from the center pin (indicator, signal) through to ground in...
The top pin is signal.
The center pin is 5v.
The bottom pin is ground.
Wiring from the center pin to ground should leave the LED on constantly.
Writing to DriverStation cRio screen alexjplant NI LabVIEW 2 17-01-2009 10:59
Wiring an LED from the OI Windward Electrical 6 21-01-2007 13:54
Team LED Gamer930 Control System 1 18-02-2006 15:57
Led tyguy2021 Electrical 7 15-11-2005 21:30
LED Flashlights Justin Chit-Chat 3 06-08-2004 05:35
