Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 17-01-2009, 15:38
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Help! :confused:
What do u use to connect the solenoid valve to the Pneumatic Bumper???
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 22-01-2009, 10:45
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Re: Help! :confused:
OK. First, what is a pneumatic bumper? Second, the air hose hooks up between fittings and the fitting screw into the pneumatic pieces. Are you looking for the fittings and couplers?
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 22-01-2009, 10:49
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The Pneumatic Bumper is the electronic part that plugs into the cRio control system. He's asking about wiring....which I have not explored. In the past it was typical to use #18 wire to connect them, but it would be wise to read thru the pneumatics manual, the control system manual, the Robot rules, and the FRC Suggestions.
http://usfirst.org/community/frc/content.aspx?id=452
I haven't looked, because we're not using pneumatics this year....
Unread 22-01-2009, 10:50
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
It's no longer referred to as the Pneumatic Bumper - it's the Solenoid Breakout (the adapter board that plugs into the NI 9472 module in the cRIO for providing easier wiring to devices such as pneumatic valves).
You can use the 2-pin cables from your Control Kit. You should have received 5 of them in your KoP.
Russ
Unread 22-01-2009, 11:04
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
The control system specs, pg 36 tells you the pinouts and what to use. I'm not sure if it's recommended against or not, but I believe a 24AWG(pg 11), 8x2, ribbon cable may also be used so long as you're very careful of polarity. Any thoughts Russ?
GitHub
Unread 22-01-2009, 11:56
As far as I'm concerned, Rule R45.G says it all - must use 24AWG or larger wire to power pneumatic valves. I'm not terribly interested in the cable details (eg discrete wire vs. ribbon vs. connector type) as long as the individual lines are 24AWG or larger.
Russ
Unread 24-01-2009, 19:22
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Another question, does it matter which GPIO port the nason pressure switch is wired to?
~thank you in advance
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 24-01-2009, 19:43
None at all. Any one of them will do.
confused, some startup help... NetSkay Programming 1 31-10-2008 21:44
Please help with our IR code, we are so confused rjn Programming 8 18-02-2008 10:40
pic: Confused Mentor Stu Bloom Chit-Chat 18 05-02-2007 08:44
Totally confused Justin Brooks Pneumatics 2 16-01-2007 15:22
