Re: Default Labview Dashboard and Windriver Example Help
If you only care about the PWMs, those can be done easily w/out WPILib changes.
You can do something like: DigitalModule *dm = DigitalModule::GetInstance(4); // 4 is cRIO slot # dashboardDataFormat.m_PWMChannels[0][0] = dm->GetPWM(1); to set the first PWM's data in the dashboardDataFormat object. Continue on down to do the rest of them (use a loop perhaps). Though if you cannot even get your hard-coded value of 50 to show up on your dashboard, then you may have another issue. Check that your dashboard's Labview install and your Windriver c++ are all at the most recent updated version so that the data packets each expects are the same. Also make sure you don't change the format or ordering of the data in DashboardDataFormat class because that will cause a mismatch with what the LV Dashboard expects. |
| Example LabVIEW Apps - Dashboard, CMUcam2 and Motors | DanDon | LabView and Data Acquisition | 3 | 29-01-2009 22:13 |
| ROBOT C and the LabVIEW Dashboard | robogeek753 | Programming | 5 | 20-02-2008 11:30 |
| Example LabVIEW Apps - Dashboard, CMUcam2 and Motors | Russ Beavis | National Instruments LabVIEW and Data Acquisition | 9 | 21-01-2007 17:19 |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 02:04 |
| Labview dashboard and multiple variables | Joe Ross | LabView and Data Acquisition | 2 | 15-03-2006 21:55 |
