Go to Post While the Banners initiate the outreach, eventually, the outreach becomes the Banner. - MysterE [more]
Unread 22-01-2009, 07:15
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
Heavy Lifting
anyone have any ideas how to make a robot pick up 600 to 700 pounds and move it? this is for a project non-related to first.
Unread 22-01-2009, 08:23
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Heavy Lifting
As I recall, 1501's 2007 bot could do just that (without the moving). Check out their design for ideas.
Hi!
Unread 22-01-2009, 14:12
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Heavy Lifting
To give any recommendation we need to know more info. Is the 600lbs on a pallet or what shape is the object you are lifting? How far and how fast do you need to move it? Any other requirements or limitations?
Unread 22-01-2009, 14:21
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Heavy Lifting
“Give me a place to stand and a lever long enough and I will move the world”
Archimedes, 220 BC
www.179swampthing.org
Unread 22-01-2009, 14:27
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Mentor
FRC #2851 (Crevolution)
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Re: Heavy Lifting
repeated heavy lifting is generally undertaken using hydraulics, if your looking for a FRC scaled solution i would go with a screw lift.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 22-01-2009, 21:14
Spen.M.P.'s Avatar
Re: Heavy Lifting
it dosn't need to be fast, but has to be able to move them. i think they are risers that are to be lifted. i am not sure how far it needs to be moved. probably less than 100 yards
Unread 22-01-2009, 23:06
CraigHickman
Posts: n/a
Re: Heavy Lifting
You probably won't need to pick them up very far, so I'd go with some sort of short stroke hydraulic, and then some hefty casters to be able to move thigns around.
Unread 23-01-2009, 00:14
Team 2021 Captain
AKA: Chris Davidson
Re: Heavy Lifting
Depending on cost, location you moving in and all sorts of other factors it could be cool to use the AndyMark 21in mecanums once they are made.
Unread 23-01-2009, 01:33
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Heavy Lifting
This reminds me. Keep in mind what you are moving acrossed. If its gym floors, Craig's idea would work great. If it was out door in the grass. Might want to reconsider. The main difference would be how high it goes and the type of wheels. However, I think hydraulics would definitely be the best for lifting.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-01-2009, 06:29
Spen.M.P.'s Avatar
Re: Heavy Lifting
thanks for all the thoughts. were thinking of jacking up the corners and puting castors under them and then just build the robot to push it.
how heavy do you want to be? coldabert General Forum 0 04-01-2009 15:54
Back Heavy Regionals Jherbie53 General Forum 8 09-03-2008 09:28
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
Is your robot top heavy? Squeje250 Technical Discussion 19 27-02-2005 12:22
Servo Stability Heavy Stuff archiver 2001 1 24-06-2002 03:54
