KoP Quadrature Encoders
Greetings from 2603; just a few quick questions. I searched and could not find all the information I need; if I missed it, I apologize; I don't want to waste anyone's time.
We have our KoP encoders mounted on our prototype chassis using AndyMark ToughBoxes and AndyMark encoder mounts. Since these were in the KoP, I was expecting there would be some sort of documentation about the sensors; I have not been able to find this -- only the documentation for the accelerometer and gyro -- not even on the OEM's page for the encoders, so I cannot find the number of pulses per revolution. The OEM's page says that it will have 400-1440 PPR; is there anything more specific, or a way to set this? Additionally, I see in the documentation for the Encoder class for C++ that we can use the pulse width in microseconds; is this information a viable alternative to the number of pulses to determine RPM, or, what is it useful for? Thank you for your time! |
Re: KoP Quadrature Encoders
There is some info (including part #) on this Andymark page Using the part # you should be able to find any information you need on the manufacturers page.
There are 250 pulses per rev on the encoder. |
| Help Programming a Quadrature Encoder | programmr | Programming | 17 | 20-06-2008 10:40 |
| Encoders..... | manderson5192 | Programming | 4 | 07-02-2008 10:10 |
| Quadrature shaft encoder source | billbo911 | Kit & Additional Hardware | 7 | 06-01-2008 19:52 |
| Turning a gear-tooth sensor into a quadrature output encoder | Jared Russell | Programming | 4 | 18-01-2006 22:19 |
| Quadrature encoders | Max Lobovsky | Control System | 7 | 14-03-2004 18:25 |
