Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 22-01-2009, 17:46
Npiacentine's Avatar
Npiacentine Npiacentine is offline
Junior Member
AKA: Nick Piacentine
#1212
Npiacentine is an unknown quantity at this point
Digital Pressure Sensor
Has anyone found a pressure sensor that is able to interface with the cRio? We want our program to be able to know the exact (+/- 5psi) pressure, rather than the 1/0 output 120 Psi pressure switch.
Thanks,
Nick
Mentor Team 1212, 2449
Unread 22-01-2009, 18:12
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Digital Pressure Sensor
Try this one Omega has several other sensors available. You want one that put out a DC voltage that is proportional to the pressure.
Good luck.
/edit/ By the way, what you want is an ANALOG transducer, not digital. you hook the DC output to an input on the analog module. You can then calibrate the sensor to whatever range you want. Hope this helps.
Former Mentor Team 1771
Former mentor Team 4509
Unread 22-01-2009, 18:17
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Good luck.
The one thats pictures there is differential. If you order this type make sure you choose gage.
Also, none of those can go to 120 PSI and only 1 can go above 60 PSI
___________________
- Tennyson, Ulysses
Unread 22-01-2009, 19:01
martin417's Avatar
AKA: Martin Wilson
To get gauge pressure with a differential transducer, just leave one side open to atmosphere.
I am guessing he is interested in pressure he can use, and since you can't use pressure over 60 PSI, there is no need for anything more. This is an inexpensive solution to his problem. Omega offers others, but they are more expensive.
Unread 28-01-2009, 23:32
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Nick, I can get you a sensor that will measure to 250 psi (gauge), 99% or 99.5% accurate (I forget -- I'll have to check tomorrow), has a 1/4" NPT fitting and is powered by 5V. PM me if interested.
Cheers,
-Neil.
Unread 03-02-2009, 15:24
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
but, all pneumatic components MUST be rated to over 150 psi...
be careful
[center]
Unread 03-02-2009, 16:16
Cheers,
-Neil.
I'm interested... Who makes this wonderful device? Part number? Price?
Unread 03-02-2009, 16:28
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Actually, 125PSI is the required min rated pressure (not 150PSI).
http://www.meas-spec.com/downloads/M5100.pdf
Around $100 each from Digi-Key in single piece quantities.
Russ
Unread 04-02-2009, 02:58
ZInventor's Avatar
AKA: Zeno Le Héricy
Russ
oops, well, below 60's still below 125...
[center]
Pressure Sensor lasereyes Pneumatics 3 18-02-2008 02:02
pressure sensor drosophyllum Pneumatics 6 05-12-2007 20:49
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Pressure Sensor Readings ErichKeane Pneumatics 17 28-01-2004 09:58
