Go to Post If I was a balding man, and Dean Kamen signed MY head, I'd immediately make my way to the nearest tattoo parlor and have them make it a permanent fixture. I wouldn't have washed it off! Just saying. - Carolyn_Grace [more]
Unread 22-01-2009, 18:21
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
lathe turning wheels- is it against the rules?
We have decided that more wheels does actually equal enough of an advantage that we are planning to stack our wheels three wide. Question- in order to ensure that each wheel is continually in contact with the regolith, we are considering turning them on the lathe together and using a levelling stick to sand them even with each other, then buffing them to a surface texture equal to that with which they came in the KOP.
The question is, is this legal? While we appreciate your concern about coefficient of friction and all that, please don't worry about giving us advice on the number of wheels. We simply want to know if we can resurface them without attempting to add traction to the surface of the wheel.
Thanks!
Unread 22-01-2009, 18:24
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Re: lathe turning wheels- is it against the rules?
i dont think so due to whatever rule number stating the wheels must be in as close to out of box condition as possible.
Unread 22-01-2009, 18:32
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Thanks!
Originally Posted by <R06>
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
As per the above bolded section, what you propose would not be allowed.
___________________
- Tennyson, Ulysses
Unread 22-01-2009, 18:34
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Robot rule 6 says, in part:
"The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear."
So, no, lathe turning of the wheels for uniform diameter is not allowed.
Unread 22-01-2009, 18:45
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
They are probably molded to already be as close as you would get them with a stick and sandpaper. Surely they are within the slop that will be present in the bearings they are mounted with.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 22-01-2009, 18:58
mrnoble's Avatar
teacher/coach
Thanks, everyone. They are already within pretty close tolerances, as you say.
Changing the subject a bit- our practice wheels, which have only been used for about 1 hour, already show significant scratching; enough that we are concerned about durability at the competition. Do you think that FIRST will have a large stockpile of swap-outs on hand and will require teams to switch who have been practicing to the point where the wheels have additional traction?
We certainly weren't asking this because we want to violate the spirit of the rules regarding wheel modification ; if anything, we wanted to make sure ours were in as close to delivery specs as possible. I'm hoping that there won't be many who come to the competition with worn wheels due to "normal wear" who intended it to be an advantage; I remember there being posts to that effect a couple of weeks ago.
Again, thanks for the input. Good luck to all!
Unread 22-01-2009, 19:21
The big guy
As part of the last team update they listed a method that can be used to repair your wheels if they are scratched. Basically sand the scratches off and buff them back to a "shine" your fingernail shouldn't catch in any of the marks left on the wheel.
Justin Stiltner
KI4URQ
Help Team 245 Support the Fight Against Cancer! RyanCesiel General Forum 0 14-05-2008 21:02
Regional-specific rules, etc., and do the referees read the rules? Kit Gerhart Rules/Strategy 53 18-04-2005 08:51
Turning the Robot Idaman323 Electrical 2 18-02-2005 00:48
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
