Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 22-01-2009, 19:24
boehmz boehmz is offline
FRC #1730
boehmz is on a distinguished road
Move Gizmo far Away from Object
I am using physique to constrain several objects to a biped. I want one of these objects to be able to rotate without moving the biped. After applying physique, the rotate gizmo stays at the spot where the biped was in figure mode, causing the object to rotate around the axis I want. Any way to fix this? The only thing I've tried is XForm, but I would have to move the gizmo with the object throughout the animation(I think).
Unread 22-01-2009, 20:55
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Move Gizmo far Away from Object
I have to say I want to help. But I know nothing of the Physique modifier and I refuse to animated with a biped (its a horrible rig in my opinion. I can build easier ones myself). I did try, I looked at the Physique and went
Might I suggest an alternative path?
You can build a custom rig using bone objects and IK joints and use the skin modifier. Then if you have any pinching you can always use the skin deform. If you put a snapshot up of your character I maybe able to help see the best route to take. I've found most of the time when students have a difficult time with 3DS is because they've taken a difficult and buggy path to accomplish things.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 23-01-2009, 18:51
FRC #1730
Couldn't figure it out, not even google could solve my problem. I ended up changing it to an attachment constraint to avoid the problem.
Off-Season Challenge - I Like to Move It, Move It! Kevin Thorp 3D Animation and Competition 11 03-11-2008 16:04
1346 Far from Finished... dtengineering Robot Showcase 4 09-02-2008 21:30
Cmaera semi-running away from light amateurrobotguy Programming 3 04-02-2006 17:23
GETTING AWAY FROM THOSE WALLS? J15.5h General Forum 6 10-12-2004 16:13
Ucf so soon...but yet sooo far away Ryan Albright Regional Competitions 20 23-03-2003 21:19
