crab drive
how many other teams r goinlg with a crab type orientation vs. a 4 wheel steer?
Re: crab drive
We're doing a 4 wheel Crab.
Re: crab drive
when did San Luis Obispo, CA get a frc team?
Re: crab drive
Crab here as well. I've posted many tidbits about what we're doing on it in several of the other threads out there. I'm sure the search function can lead you to them.
Re: crab drive
Re: crab drive
that sounds good to do a crab drive
#7
Re: crab drive
I am doing a 8 wheel crab. =)
#8
Re: crab drive
how are you doing that does it work fine did you work out the variables
#9
Re: crab drive
Hm. Two wheels per module, with a set of miter gears between them?
#10
Re: crab drive
Nope, I am just using lots of skills. =)
#11
Re: crab drive
we, were going to, but ran out of time
#12
Re: crab drive
whats crab drive
#13
Re: crab drive
its were the 28" are the sides and the 38" are the front and back
#14
Re: crab drive
How is the crab working for you guys anyway? we decided to use 4 wheel drive instead of it, what made you decide to use crab drive?
#15
Re: crab drive
Crab drive is where the robot has the ability to rotate its wheel effectively steering them, while having them powered also. There are many different styles of doing this. Do a quick CD-media search for "crab drive" or "swerve drive" and you'll see plenty of examples. |
| Crab Drive | RMS11 | Robot Showcase | 46 | 05-09-2008 22:34 |
| Crab drive question | peter_p | Technical Discussion | 15 | 15-08-2008 15:18 |
| Crab Drive | nukelear1991 | Programming | 13 | 21-12-2007 18:02 |
| Crab Drive | Joe_Widen | Technical Discussion | 9 | 21-04-2006 21:50 |
| Crab Drive | Collin Fultz | Technical Discussion | 3 | 04-09-2002 16:35 |
