Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 01-22-2009, 09:56 PM
bomber7 bomber7 is offline
Humanoid
FRC #0585
bomber7 is an unknown quantity at this point
Question Multiple threads
I am using Windriver Vxworks, C++.
In the previous controller if I wanted something to happen periodically independent of the rest of the code I could use interupts.
This year as far as I can tell interupts are no longer usable. Instead, it seems that a better solution would be available. If I could start a second independent thread I could use an infinite loop with a Sleep() in it to achieve the same effect. However, it seems the normal C++ method of starting another thread does not work.
It is my understanding that normally you can use "_Fork <functionname>" (without <>) to start a function on another thread. The compiler says that _Fork is undefined, so I'm wondering if anyone has a different solution?
Unread 01-22-2009, 10:07 PM
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Multiple threads
There has been some discussion on the use of threads/tasks using WPI's wrapper, here are a couple of threads that deal with it.
http://www.chiefdelphi.com/forums/sh...ad.php?t=72371
http://www.chiefdelphi.com/forums/sh...ad.php?t=72607
http://www.chiefdelphi.com/forums/sh...ad.php?t=72439
Although you may still be able to use interrupts. Look into Encoder.h and Encoder.cpp
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-22-2009, 10:39 PM
Humanoid
FRC #0585
Awesome, thanks, I got what I needed from those threads, for some reason my search didn't turn up any of those threads.
Thank you for the help.
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 01-02-2009 08:37 PM
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 12-22-2007 01:09 AM
threads Pin Man CD Forum Support 1 02-23-2003 07:49 PM
