Go to Post Back to robotics!!!!! - Steve W [more]
Unread 23-01-2009, 01:25
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: pic: Pic 2: "caster wheel" crab drive combo
How exactly is it supposed to work on a robot. I understand how the module itself works, but when you put it on the robot 'as-is,' wouldn't it just spin in circles?
Please explain... I'm curious...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 23-01-2009, 02:53
adengler's Avatar
adengler adengler is offline
Mr. Dengler
AKA: Aaron Dengler
FRC #2090 (Buffnblue)
adengler will become famous soon enough
We'll try to post more info/pics as it develops. The idea is to link two of these units together with a tie rod as in "ackerman steering".
2090 BuffnBlue | Punahou School | Honolulu, HI
Unread 23-01-2009, 11:01
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Very similar to some ideas that we had for setting up a crab drive or ackermann drive system.
did you try direct driving the wheels rather than using the chain? could save you some weight and be a little cleaner setup - not sure if you would have enough clearance for the caster setup though.
Other than that - I love it.
Unread 23-01-2009, 11:59
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
We're doing direct drive on our 6wd, which made me think about why they weren't doing it. I figure that with the direct drive, they'd have to support the end of the shaft to keep from getting any negative cantilever forces on the wheel. Since they aren't doing a standard crab module, they really don't have an easy way to support the end of a direct drive shaft.
With the two little side plates going down to support the chain driven wheel, they instantly have a well supported wheel with no cantilevering.
At least, that's how it seems to me.
-Greg
Unread 23-01-2009, 14:59
JHSmentor's Avatar
FRC #3210 (Falcons)
-Greg
Yes, I had the same concern with the cantilever affect but I found a way to mount the wheels very close to the toughbox as a direct drive (through some good luck while using Autodesk). with the low friction surface this year and decent weight balancing, I think this will work out fine. But, supporting the wheel on both sides eliminates that concern so it should be more robust with the only real downside being added weight.
Unread 27-01-2009, 21:14
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
my suggestion is that you use wheels that turn under your control, a design like that would have you doing donuts
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: Crab Drive Frame evanisthat! Extra Discussion 15 19-12-2007 20:04
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
