Go to Post I continue in FIRST because I'm not looked down upon for not knowing how to do something, but held up because I want to learn. - LemmingBot [more]
Unread 23-01-2009, 06:06
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
PIC: 1902 Exploding Bacon proto type base
This is a working base we use.
What is it used for?
Doug Leppard
Unread 23-01-2009, 09:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: PIC: 1902 Exploding Bacon proto type base
I don't know what you use it for, but it would be good for several things...towing a trailer around for your PS to practice, or testing different steering/drivetrain concepts, or showing off your throwing-things-together-and-making-them-work skills
Unread 23-01-2009, 09:25
Gabe Salas Jr.'s Avatar
Gabe Salas Jr. Gabe Salas Jr. is offline
Ri3D 1.0
AKA: CrazyBear
FRC #0233
Gabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant future
I don't see any chains or drive systems.
There is a three wheel base (look at the shadow).
Dunno if there is a direct drive motor to the single wheel axle (looks like it can rotate at 360 degrees).
hmm...
"Confidence, not arrogance."
Does your robot use its powers for good, or for awesome?
Unread 23-01-2009, 09:27
MrForbes's Avatar
AKA: Jim
It looks like there's a planetary transmission on the other side of the front wheel, which is mounted to the bottom of a lazy susan bearing.
Unread 23-01-2009, 09:31
Good guesses so far.
Hint:
Three wheel bot with all wheels fixed in forward direction, front wheel is driven wheel.
Doug Leppard
Unread 23-01-2009, 09:46
Brandon Holley's Avatar
I also see non-rover wheels on that frame....HMMMM very interesting...
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-01-2009, 09:51
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
You've probably thought about it already, but having the 2 non-driven wheels NOT Rover wheels will open you up possible issues at a Regional with the inspection team. I know a non-driven wheel used to gather data has been OK'd by the GDC in the Q&A Forums, but these are obviously weight bearing wheels and have increased traction thereby limiting the lateral stability.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 23-01-2009, 09:56
Rizner's Avatar
Rizner Rizner is offline
FRC #2425
Rizner has a spectacular aura aboutRizner has a spectacular aura about
To prototype of course.
Unread 23-01-2009, 12:19
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
The front wheel is powered and from what i can tell it looks like it can pivot. It is possibly the turning wheel, so maybe you turn and propell with a single wheel on a lazy susan.
Unread 23-01-2009, 13:40
This is totally a proto type to test an important part of our drive system. Our competition bot will be a four wheel robot. Our competition robot will only have kit wheels used for traction and weight baring.
Ok this is what it us used for.
To test the Pig Traction Control (PTC). PTC is being designed to not allow the wheels to slip during acceleration and stopping.
The one wheel is driven to test the interaction without other three wheels interacting if it was on a four wheel robot.
Doug Leppard
Unread 23-01-2009, 13:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If the front wheel is the only driven wheel, and it's 3 wheeled, I'm going to say that front wheel must pivot to turn. That leaves you with either ackerman, or crab steer. Since crab is really unneeded because you have no need to turn more then 180 degrees, I'm going to say ackerman via a linkage of some sort.
Are you concerned that with 3 wheels on the floor and only 1 being driven that you're giving up 66% of your frictional force?
Unread 24-01-2009, 12:17
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
I dont think it turns. It's a programing test platform for some nifty stuff we are working on.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
pic: IRI: Exploding Bacon with Paul's Gilt David Brinza Extra Discussion 6 31-07-2008 00:22
pic: Team 1902- Exploding Bacon 2008 Robot Matt_Kaplan1902 Extra Discussion 33 11-02-2008 13:32
pic: Exploding Bacon lego version dbell Extra Discussion 12 01-05-2007 15:28
Video Autonomous 1902 Exploding Bacon Doug Leppard General Forum 16 27-02-2007 12:44
pic: 1902 Exploding Field Stephen Kowski Off-Season Events 11 11-06-2006 12:23
