Re: COF help?
I have observed, but not measured, significantly lower COF when static friction is lost.
Re: COF help?
Rolling friction (where the surface of the wheel at its bottom point doesn't slip relative to the floor) should be equivalent to static friction for non-deformative surfaces.
Re: COF help?
"When reporting local COF measurements, please include details of your methodology, such as using a fixed wheel drag sled, vs using a weighted robot with KOP wheels pulling a scale pulling a dragsled. |
Re: COF help?
So I assume you have an algorithm in your drive code that determines when your wheel is slipping and backs off the power? Certainly possible - compare omega R of the wheel to integrated speed at the wheel from the yaw rate and accelerometer. Or just calculate it from static friction and never apply more than that amount of power, but if you do start to slip it's not self correcting since the power requred decreases. Otherwise if you're applying full power to the wheels you can expect them to slip.
| Cof | XXShadowXX | Technical Discussion | 1 | 05-01-2009 08:54 |
| Grab Frame - Help Help Help... | nmihailidis | Programming | 2 | 04-03-2007 14:44 |
| section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) | naor52 | Programming | 14 | 24-02-2007 01:19 |
| Help: How do we get a teacher to help? (was: Help) | ChaosAlchimey | General Forum | 13 | 21-01-2007 11:57 |
| .cof help errors | rholokleolke | Programming | 2 | 27-01-2006 11:01 |
