Go to Post Will we finally get to play music on our robots for once!? - Hitchhiker 42 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 04-01-2009, 08:56
GaryVoshol's Avatar
Cogito ergo arbitro
Last year's kit frame
Since to be able to use last year's kit frame you had to fabricate it (cut it to length), it would not be allowed on this year's robot per rule <R33>. "FABRICATED ITEMS from ROBOTS entered in previous FIRST competitions shall not be used on ROBOTS in the 2009 competition."
IFI still has the old kitbot frame on their website, so it could be purchased and used this year. I'd suggest any team doing so have a receipt available for inspectors.
(since 2004)
Unread 04-01-2009, 10:09
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: Last year's kit frame
I don't believe a receipt is totally necessary. You are allowed to use a previous year's kitbot frame IF is composed of parts that are still available from the companies that provided them. These parts would just need to be properly spec'd and accounted for on the teams BOM (Bill of Materials, for you rookies ).
HOWEVER, parts from previous years kits that are no longer commercially available to all teams OR are not legal by all rules that pertain to the robot may NOT be used.
Hope that clears some things up.
EDIT:
For anyone trying to find part numbers or prices of previous year kit parts link is below.
http://ifirobotics.com/kitbot.shtml
Unread 07-01-2009, 16:52
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Also, no where in the rules does it say COTS parts have to be purchased after any particular time (for example Kickoff). We have one complete, unused KitBot and most of the parts for a second one that have been purchased separately at various times over the past 3 years. I don't find any rule stating that we can't use the old KitBot materials even from 3 years ago as long as we haven't cut/modified them (fabricated) and IFI is now still selling them after Kickoff (as COTS) so that any team could buy the same if they wanted to. We would, of course, have to declare the current purchase cost on our cost accounting/BoM at inspection but nothing I have read limits when the purchase has to have occured. No team buys all new raw stock each year and throws out all their unused aluminum/plastic/etc. left over from the previous year so why should the KitBot be any different? In fact, as far as I can tell a veteran team that didn't use their issued KitBot from some previous year that say just stuck the box on the shelf and built a custom frame that year would be perfectly legal to pull that old IFI KitBot box off the shelf and use it this year if they wanted to as long as they accounted for it in their cost analysis.
If it is FIRST's intent to not allow teams to use the IFI KitBot this year they better hurry up and define that in the rules. If they did I think it would be rather un-GP of FIRST to single out one specific COTS part from one specific vendor and make it illegal. It would also further add to the rumors regarding the IFI/FIRST split.
This is sort of why I was asking the questions I did in this thread. Both the AndyMArk C-Base and the IFI KitBot retail for ~$190. Both are basically functionally the same. Why come out with something new if it isn't better or cheaper? FIRST has to have a reason but why?
Unread 07-01-2009, 16:57
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by DeepWater View Post
This is sort of why I was asking the questions I did in this thread. Both the AndyMArk C-Base and the IFI KitBot retail for ~$190. Both are basically functionally the same. Why come out with something new if it isn't better or cheaper? FIRST has to have a reason or but why?
In case you hadn't noticed by now, FIRST has cut a lot of ties with IFI over the past year alone (control system being the major change).
Not completely of course, as we can still use the IFI Victor's (as I recall from the Kickoff) for the control system, & you are certainly allowed to buy things from IFI as long as they meet requirements set in place by FIRST & the manual just like any other supplier of compents, since they are in fact a supplier of COTS items, but in the future I expect a lot less IFI products included in the kit or none at all.
This chassis this year is just one of them.
Unread 07-01-2009, 17:07
Yep, agreed. What I meant was why change what isn't broken just for the sake of change? If, for example, the new AM C-Base was a lot lighter or cheaper than the IFI KitBot then great I understand but if it isn't then why? If FIRST some how intends for us to not be able to use the IFI KitBot and specifically outlaws it then that will come across (to me at least) as just plain mean and spiteful toward IFI who has always been a loyal supported of FIRST as far as I have ever seen.
Unread 23-01-2009, 07:07
GaryVoshol's Avatar
Cogito ergo arbitro
An update from the GDC: http://forums.usfirst.org/showthread.php?t=11519
Last year's kit frame is considered custom-made for FRC 2008, so cannot be used. You'd have to buy a new IFI kitbot to use it this year.
(since 2004)
Unread 23-01-2009, 07:15
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I hope for the GDC's sake there is a difference between what was in the 2008 kit and what is available here. If not the GDC has stooped to a new low in getting involved with FIRST politics.
Unread 23-01-2009, 11:05
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Food for thought:
The one in the KOP last year was identical to the one we sold last year and is identical to the one we're selling now.
-John
Unread 23-01-2009, 11:15
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Is it just me, or is it weird that that link goes to the 2008 Q&A Response Forum, as opposed to the 2009 Q&A Response Forum?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 23-01-2009, 11:24
Looks like people are posting 2009 questions accidentally under the 2008 forums.
(Just look at the dates of the posts for any clarification.)
I agree that is completely confusing, & that FIRST should lock all 2008 forums at this point!
Unread 23-01-2009, 11:34
Jared Russell's Avatar
Taking a year (mostly) off
Originally Posted by JVN View Post
Food for thought:
-John
Then I vehemently disagree with the GDC's ruling.
On the plus side, as far as I know there is no way to "carbon date" an aluminum alloy to figure out when it was made...
Unread 23-01-2009, 11:38
On the plus side, as far as I know there is no way to "carbon date" an aluminum alloy...
It'a not illegal (as a COTS item) so that just means you have to purchase it this year.
This is consistent, but the comment from the GDC that is was "custom" is not correct as they stated it apparently going by John's inside info.
Bottom line: It can still be used. Just buy it this year, have proof if necessary with a dated receipt (I haven't looked at the cost & "date purchased" accounting rules completely yet to be honest) & be good to go.
If anything, they are giving teams the call to spend money this year on an IFI component if they wish to, so in essence, it's not really getting into politics in the way one would think they would be (by denying teams to use anything IFI related) if that's the accusation, but rather it's treating IFI as any other supplier & telling teams to buy things from them this year, rather than get a "freebie" by using what you have lying around the shop from previous years.
Then again, there is also the rules in place that FIRST says "we don't care if you don't pay anything at all for a component, it just has to be accounted for in your robot budget as the price it would be off the shelf if you were to purchase it." (with the usual other restrictions in place following the flowchart of course)
So.. technically, you could "find" & get a 2008/2009 chassis "donated to your team" from in your team closet from last year for free, but still account for it for the price it would cost you this year if you were to buy it from IFI.
Confused yet?? I know I am slightly. lol
Unread 23-01-2009, 11:44
Brandon Holley's Avatar
Bottom line: It can still be used. Just buy it this year, have proof if necessary with a dated receipt (I haven't looked at the cost & "date purchased" accounting rules yet to be honest) & be good to go.
What disturbs me isnt the fact that it can still be used...its the fact that according to JVN (who I'd say is an incredibly reliable source...) the kit frame has not changed since it was put in the KOP in 2008.
I am interested to see what parts are custom from 2008...edited to not offend anyone, as that was not the original intent of my post
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-01-2009, 11:50
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
In ten years, I've not once been asked to produce a receipt in support of our Bills of Materials.
So many things are already enforced through 'gracious professionalism,' that I can't really understand why it'd suddenly become necessary for teams to be able to provide documentation for any or all purchases. Teams using an IFI chassis should be aware of the rules regarding its use -- particularly that it's still available as a COTS item -- and be able to relate that information if questioned. A team's word -- especially where it relates not to issues of safety -- should be as good as gold for inspectors.
--Madison--
...down at the Ozdust!
Unread 23-01-2009, 11:51
Well said!
Last Year's Gyro sparrowkc Rules/Strategy 4 21-01-2008 17:07
can we use motors from last year's kit? Amittt Motors 5 22-01-2006 22:27
Last year's motors? archiver 2001 2 24-06-2002 00:33
