Go to Post Focus on solving the problem, not on being deliberately creative. If you effectively solve the problem, creativity is naturally leveraged as part of finding a great solution. - Jim Zondag [more]
Unread 23-01-2009, 14:44
Re: Gryo Connection
Originally Posted by EricVanWyk View Post
Can you describe what signal you are getting and show us your code?
It is also possible that you received one of the units that had the labels for Rate and Temp swapped, but I believe those came with notes clarifying the mistake.
The signal was pretty constant with a bit of noise, around 10 mV. It peaked at ~0 and ~20mV.
This has been tested with 2 of the 2009 kit gyros. Both produced similar results. We borrowed another local team's unit to test with, so if a bad batch (reversed R/T labeling) was sent to our regional kickoff, that could be the issue.
As Eric stated above, we tested this with the sample gyro code in LabView and using C++. The accumulator for the gyro angle was going through the roof, which matches up with the relatively low signal. I am almost certain this is not a code issue.
Internet Connection? synth3tk Scouting 15 08-03-2008 10:33
Battery Connection neoshaakti Electrical 4 12-01-2008 14:57
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Spike Connection Gal Longin Control System 4 12-01-2005 13:59
Championship Connection Jordan Rumor Mill 3 13-11-2002 22:41
